wont go in to 4 wheel drive - JeepForum.com
post #1 of 6 Old 04-19-2008, 07:39 PM Thread Starter
concretewake310
the shifter is very hard to move and I dont want to brake it so I am not going force it. It went into 4 wheel before and it was easy to move. When it went in to 4 wheel before every thing worked great. Dose anyone Know if I am doing some thing wrong or do I need to fix some thing?
concretewake310 is offline
post #2 of 6 Old 04-19-2008, 08:34 PM
Pete M
1988 MJ Comanche
Have you tried moving forward lightly as you shift?
Jeep on!
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #3 of 6 Old 04-19-2008, 08:38 PM Thread Starter
concretewake310
Yes forward and backward.
post #4 of 6 Old 04-19-2008, 09:30 PM
maddzz
1989 MJ Comanche
Did you try pushing the shifter over to the right while you are shifting.
maddzz is offline
post #5 of 6 Old 04-19-2008, 10:31 PM Thread Starter
concretewake310
yes it is verry hard to move the shifter. I can tell where the spots are for 4H and 4L. the one time I got it to work it went in real smooth and was not hard to move.
post #6 of 6 Old 04-20-2008, 08:04 AM
Pete M
1988 MJ Comanche
It's possible that the linkage might have come loose.
--Pete
My email:
Pete M is offline
4 Wheel Drive wont engage. aleebee156 XJ Cherokee Technical Forum 13 11-30-2013 06:22 PM
Converting a 2 wheel drive to a 4 wheel drive Greg_Towle XJ Cherokee Technical Forum 4 09-24-2009 07:42 PM
87 Cherokee Chief/ 4 wheel drive wont engage! JonathanDB XJ Cherokee Technical Forum 5 09-18-2009 05:06 PM
xj wont run when in drive ytbrown XJ Cherokee Technical Forum 4 05-28-2009 02:03 PM
Wont Go Anywhere In Drive CSprinkJR XJ Cherokee Technical Forum 2 12-16-2007 06:17 AM
