Wj booster won't fit - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > MJ Comanche Technical Forum > Wj booster won't fit
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 10-23-2013, 05:33 AM   #1
bwiygul
2010 WK
So I picked up an 04 wj booster and mc to put in my 92 man and the rod is nearly identical length, the wj is 1/16 longer I think. Anyway, the booster hits the lip at the top and the drivers side where the bottle should go. My bottle is on the passenger side though.
Any suggestions? Will the 95/96 xj be a better fit? Do I just grind out the problem spots on the body? Anybody know what the deal with this is? I've read and read for two weeks to make sure I have everything right and now I run into this. Thanks for any input.
bwiygul is offline   Reply With Quote Quick reply to this message
Unread 10-23-2013, 06:06 PM   #2
dkroll
1988 MJ Comanche
I used a 96 XJ MC and booster- no problems.
FYI
Doug
dkroll is offline   Reply With Quote Quick reply to this message
