Will 88 Cherokee Flares fit 88 Comanche - JeepForum.com
post #1 of 4 Old 06-06-2008, 12:12 AM Thread Starter
mknherhappy
Will the Fender Flares off of an 88 Cherokee fit the 88 Comanche front and back?
thank you.
mknherhappy is offline
post #2 of 4 Old 06-06-2008, 08:59 AM
SoloCamo
1988 MJ Comanche
Only 4 door fronts will fit IIRC.
Engine: Cutout+Insulated Airbox | Ford Design II 19lb injectors
Suspension: Gabriel VST Shocks
Tires: Firestone "Firehawk Indy 500" 235/70/15's
SoloCamo is offline
post #3 of 4 Old 06-06-2008, 01:56 PM
jeepicon-com
the rears will not fit.
jeepicon-com is offline
post #4 of 4 Old 06-06-2008, 02:05 PM
Pete M
1988 MJ Comanche
2door/4door XJ and MJ fronts are all the same. MJ rears are different than both 2door and 4door XJs
Jeep on!
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
cherokee axles under a comanche? 89SAFARIXJ MJ Comanche Technical Forum 15 05-16-2009 12:49 PM
Comanche rear fender flares? motorr50 MJ Comanche Technical Forum 8 10-01-2008 10:27 PM
Will Cherokee Seats fit the Comanche? dlagrua MJ Comanche Technical Forum 8 10-03-2007 12:08 PM
Will Cherokee axles fit a Comanche? 97powerstroke MJ Comanche Technical Forum 6 06-10-2005 10:50 AM
Cherokee 2 dr / Comanche Same Flares? MJ Rat XJ Cherokee Technical Forum 1 04-11-2005 08:57 PM
