What weight differential oil for MJ Dana 44 - JeepForum.com
post #1 of 10 Old 03-07-2012, 04:03 PM Thread Starter
JeepComanche89
1989 MJ Comanche
I was wondering what weight differential oil is best for a front and rear Dana 44 from a comanche. Also how do I find out the oil capactiy of the differentials. I ask this because the rear axle is on a 6 degree shim. It will be a daily driver as well as a part time wheeler, and im planning on using 32 inch tires if that makes a difference. Thanks in advance
JeepComanche89 is offline
post #2 of 10 Old 03-07-2012, 05:30 PM
ftpiercecracker
1990 MJ Comanche
90 weight maybe heavier?, and just fill till overflowing. make sure your axle vents are clear.
ftpiercecracker is offline
post #3 of 10 Old 03-07-2012, 05:57 PM Thread Starter
JeepComanche89
1989 MJ Comanche
Thanks but dosent the shimmed rear change when the liquid overflows?
post #4 of 10 Old 03-07-2012, 06:34 PM Thread Starter
JeepComanche89
1989 MJ Comanche
Also is there a certain brand of oil I should buy?
post #5 of 10 Old 03-09-2012, 01:30 PM
ftpiercecracker
1990 MJ Comanche
Well, the way i figure it once its overflowing theres not much else you can do, except maybe drill and tap another fill hole higher up on the diff, but thats JUST an idea and as for the brand i dont really think it makes much of a difference for diff oil, just ask for "gear oil" at your auto parts store and they should point you in the right direction. I run 90 weight, just as an example, dont even know the brand. I'm sure there are "high performance" gear oils, but i highly doubt you are going to need it.
recap: fill till overflowing, use 80w-90 gear oil you pick the brand.
post #6 of 10 Old 03-09-2012, 01:35 PM Thread Starter
JeepComanche89
1989 MJ Comanche
Gothcha thanks. Just never did diff oil before and wanted to make sure
post #7 of 10 Old 03-09-2012, 04:19 PM
ftpiercecracker
1990 MJ Comanche
The only stipulation I can think of, is that if your diff is a limited slip you will need an oil additive, dont know about lockers. If'in you do have a limited slip, they have the additive you need at the auto parts store.
post #8 of 10 Old 03-10-2012, 08:50 AM Thread Starter
JeepComanche89
1989 MJ Comanche
Actually my diff is a limited slip. I bough 75-90 oil labled limited slip. Is that ok I did not change it yet.
post #9 of 10 Old 03-10-2012, 08:00 PM
ftpiercecracker
1990 MJ Comanche
Since I am not there to lay my eyes on the jug itself, i would ask the guys from where you bought it from if they think it would be suitable for your application, just to be sure.
post #10 of 10 Old 03-11-2012, 08:44 AM Thread Starter
JeepComanche89
1989 MJ Comanche
Got it thanks for your help
Rear Differential...What Weight? mtl4life XJ Cherokee Technical Forum 3 12-22-2007 03:00 PM
help please!! weight of an MJ. Beachbum1236 MJ Comanche Technical Forum 4 10-07-2007 02:05 PM
How much weight is to much? UTHornsFan XJ Cherokee Technical Forum 8 07-05-2006 08:48 PM
Differential fluids...Transfer Case Fluids...What weight? TheZaZ XJ Cherokee Technical Forum 7 06-01-2006 11:31 PM
differential (dana 35) xjcountry XJ Cherokee Technical Forum 2 10-01-2004 12:41 AM
