Quantcast what should i watch for ? new to jeep's. . . - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Comanche Technical Forum > what should i watch for ? new to jeep's. . .
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 11-03-2009, 10:30 PM   #1
AMCSportTruck
1988 MJ Comanche
I just bought myself a 1988 AMC Jeep Comanche Sport Truck.
specs:
2.5L-I4, 4spd-DD, 4.10 gears 215/70R15 front and 225/70R15 rear.
Truck is a 2wd regular cab short bed as best i can tell.
Is there any item's I should be worried about or keep an eye on ?
thing's like what its weak point's ? / whats known to fail ?
Thanks
Mike
AMCSportTruck is offline   Reply With Quote
Old 11-04-2009, 12:06 AM   #2
BLKGRANDJP
Anything plastic or rubber look for cracks. i.e. vac lines.
motor mounts. bushings and so on.
My 89 seems to like the SEA FOAM in the gas. and air intake every so often.
oh and the in dash lcd screens for the navigation system are prone to fail. :-)
00 WJ 4.7L
99 XJ 4.0L
89 Wrongler
BLKGRANDJP is offline   Reply With Quote
Old 11-04-2009, 01:50 AM   #3
TheDann
TheDann is offline   Reply With Quote
Old 11-04-2009, 12:11 PM   #4
Pete M
1988 MJ Comanche
some good reading here:
ComancheClub.com • View topic - What is the most important tip you'd share with MJ owners?
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email: petermontie@hotmail.com
ComancheClub.com/forums
Pete M is offline   Reply With Quote
Old 11-04-2009, 07:08 PM   #5
AMCSportTruck
1988 MJ Comanche
Thanks much for all the info. . .
Mike
Old 11-05-2009, 03:00 PM   #6
cbordea
check under the carpet for rust, make sure the battery terminals are clean, jeeps like clean battery terminals and don't run good without a good connection.
don't run it hot.
88 MJ I6 4x4 Stock my hauler - Sold
98 XJ I6 4X4 Stock my son's DD
06 12V Purple Barbie Jeep my daughter's DD :-)
cbordea is offline   Reply With Quote
Old 11-05-2009, 04:44 PM   #7
AMCSportTruck
1988 MJ Comanche
Carpet these had carpet ? My truck has rubberized flooring, anywho i haven't looked under it tho maybe i should.
If its rusty do they make patches ? or would i have to make my own ? . . . truck didn't look rusty under neath it. . .
Mike
Old 11-05-2009, 04:49 PM   #8
Pete M
1988 MJ Comanche
There are a dozen ways for water to leak into the cab and once it's in, it rots the floors from the inside out. In fact, all of the problem areas on our trucks rot from the inside out. Rockers, floors and above the rear flares.
Old 11-05-2009, 05:23 PM   #9
AMCSportTruck
1988 MJ Comanche
Ok I will check that out.
another question they list 2 tire sizes for my truck a 225/75R15 2wd and a 235/75R15 4wd.
Will the 235's fit my truck even tho its a 2WD ? as by me the 235's are cheap n plentiful. . .
Mike
Old 11-05-2009, 09:38 PM   #10
Pete M
1988 MJ Comanche
I had 30s on my 88 back when it was 2wd. 235s should fit fine.
Old 11-06-2009, 05:07 PM   #11
AMCSportTruck
1988 MJ Comanche
I think i'm going to run the 235/75's on it then when i do the AMC V8 swap over i'm going to go with 235/60R15's on front and 235/70R15's on rear give it that lil'bit of a pro street slant to it.
But the tires aren't set in stone also been thinking about a 4wd conversion and running 31x10.50's. . .
Mike
Old 11-07-2009, 02:20 PM   #12
AMCSportTruck
1988 MJ Comanche
Say guy's how do i go about IDing the 4spd trans in the Comanche ?
Mike
Old 11-07-2009, 04:49 PM   #13
Pete M
1988 MJ Comanche
AX-4 if it's a manual trans
Old 11-07-2009, 05:24 PM   #14
AMCSportTruck
1988 MJ Comanche
Yup I searched around and found that put.
I still can't find the gear ratios for that transmission.
As I said I'm planning to repower this truck with an AMC V8.
I found that the 290 V8 makes 225hp n 300tq and has the same power curve as the 117hp n 135tq I4.
I was trying to find out what the AX4 ratios were so I could get a 4 or 5spd manual trans some what close as to not have to regear the truck.
Mike
Old 11-07-2009, 05:37 PM   #15
Pete M
1988 MJ Comanche
Nearly all manual transmissions contain ratios that are similar enough that it won't matter much. What are your choices for 4wd transmissions behind that engine? That will likely make the decision for you.
With 300 lb-ft or torque, be prepared to kiss that rear axle goodbye. The Dana 35 can barely handle a 4.0L. I blew mine up with 30" tires and street driving (only 2wd).
Glock Forum
