What oil in ba5/10 transmisson? - JeepForum.com
post #1 of 4 Old 08-09-2012, 08:05 AM Thread Starter
hillbilly51
1988 MJ Comanche
What type oil do I need to run in a ba5/10 transmission that has around 100K miles?
I think that the original specification was for ATF, but I believe a thicker oil would work better in this transmission.
What do the experts suggest?
thanks
steve
hillbilly51 is offline
post #2 of 4 Old 08-09-2012, 08:42 AM
crowespastureyj
Castrol 75-90 GL5 works pisser. I wouldnt switch to anything else at this stage in its life.
crowespastureyj is offline
post #3 of 4 Old 08-09-2012, 12:20 PM
automan2164
1986 MJ Comanche
You need to use a GL-4 spec, if I remember right. GL-5 has too much sulfur in the additives, and sulfur and brass syncros do not get along. I think you can still get GL-4 from AMSOIL guys.
Rob
'86 MJ 2.1L 4x4 MT LWB - Factory Diesel
'87 MJ 4.0L 4x2 AT LWB - Metric Ton
'97 XJ 4.0L 4x4 AT Country
automan2164 is offline
post #4 of 4 Old 08-10-2012, 12:08 AM
Pete M
1988 MJ Comanche
Rob you're thinking of the AX-15. Far as I know, any 75/90 will work great in a Peugeot.
ATF is for autos and some t-cases.
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
Rattle on top of transmisson? RamboPants XJ Cherokee Technical Forum 0 04-15-2012 08:51 AM
Transmisson problems Pre5tig3 XJ Cherokee Technical Forum 6 04-08-2011 09:36 PM
transmisson bands coastiemike MJ Comanche Technical Forum 2 05-04-2010 09:16 AM
Transmisson help ksturgio XJ Cherokee Technical Forum 6 02-01-2009 10:12 PM
transmisson pan problems Dook XJ Cherokee Technical Forum 4 09-09-2007 09:30 PM
