What lift are you running - JeepForum.com
post #1 of 4 Old 02-09-2005, 07:30 AM Thread Starter
cj7xjmj
cj7xjmj's Avatar
I own 2 MJ's so my lists are kinda long.
On my 89 (which I just got in Jan, and I am still sorting out what the PO did).
It is a rusty's 4.5" coils, Pro comp Fixed LCA's, with a Pro comp adj trac bar. For the rear it is a SOA conversion. It is rolling on 31 x12.5 proc omp x-terrians, with some wild off set rims.
My 90 aka Ping Pong is a beast. I will start with the front suspension mods. I am running Rusty's 6.5 coils, with RE drop brackets. For a trac bar I am running RE HD mount , bar , and brace. For disconnects I am running the JKS quicker Disco's. My tie rods are Rusty's tie rod conversion, with his steering stabilizer. For my rear set up, I am running a SOA conversion, with a long shackle (8 3/4" eye to eye). The long shackle meant I needed a SYE cause of crazy vibes at speed, plus my yoke was barely engaging the t-case. Also this set up has crazy flex, which meant the need for longer lines, so I used a 22" line that was available and a 12" hard line, with a specail mount. And As I sit right now, I can almost flex it out.
My interior mods are simple. Spray in bed liner, 96 bucket seats, Cj7 center console, Cb mounted right to the front roof brace, Mag light mounted to rear rough brace. I am also sporting Skull design tint.
For custom parts on the body I have a Flat black paint job from Rustoleium. A custom made front grill (expanded metal and 1x1 tubing), Home made front and rear bumper(front bumper being replaced with a Rigid co FBW), and home made Tail light covers( expanded metal and angle iron, with sheet metal screws). Hi-lift mounted to the inside of the bed using sway bar mounts.
Patrick
90 Comanche thing. Exo-cage, tube bed, with a few other things done Here is a link to some pics of it
If you have to ask why... Its a truggy thing and you wouldn't understand
cj7xjmj is offline
post #2 of 4 Old 02-09-2005, 07:52 PM
Drahcir495
Drahcir495's Avatar
cj7xjmj,
No lift for me yet. This is what I am looking to get - http://www.tntcustoms.com - XJ Y-Link Radus Arm Kit. I am going to wait until the kit has been used and tested so I can get some feed back on it. It looks fantastic and the few who have it are pleased.-Rich
Blue Jeep Club Member #124
-1989 Comanche - Pioneer, LB, 4.0 I6 / BA10 / NP231 / D44 f&r w/Eaton E-Lockers & 4:56 gears
Comanche build-up @
Drahcir495 is offline
post #3 of 4 Old 02-10-2005, 06:27 AM Thread Starter
cj7xjmj
cj7xjmj's Avatar
I have looked at this kit also, the x-memeber looks stout, I am just not to sure of the downward bend in the lower arms. Also the price is kinda high.
Patrick
cj7xjmj is offline
post #4 of 4 Old 02-10-2005, 07:59 AM
Country Jeep
Comanche Kemosabe
Country Jeep's Avatar
I'm just running a basic 2" BB in the front an a singe AAL in the rear...
Gave me about 2" in the front and I have no vibes. Here's the lifted product with my old tires on:
Nice 2" homebrewed BB and a set of AAL's with removed sway bar works for me
Main rig under screen-name...
, 4.0L HO I6, AW4. Daily driver.
'98 XJ Classic (moss green) 2WD, 4.0L HO I6, AW4. Restoration project.
Gone, but not forgotten:
, '94 ZJ Limited, '85 CJ7,
Blue Jeep Club Member #113
Country Jeep is offline
Anybody running this lift? Fiend101 XJ/MJ Cherokee Non-Technical Forum 1 11-05-2008 07:31 AM
Is anyone running with this lift? Yekcid XJ Cherokee Technical Forum 7 07-02-2008 04:50 PM
RE 5.5 lift anyone running it??? Stang5lgt XJ Cherokee Technical Forum 8 01-15-2008 05:45 PM
Anyone running a BDS lift?? dublord XJ Cherokee Technical Forum 10 06-21-2007 10:41 AM
Any one running this lift bizzo15 XJ Cherokee Technical Forum 5 06-07-2007 06:55 PM
