Water Pump gasket - JeepForum.com
post #1 of 8 Old 05-27-2008, 12:05 AM Thread Starter
bboybean
Water Pump gasket
Finally got my Xj to start and very quickly found out my WP gasket is done with (spraying fluid). The pump is fine but I need to replace the gasket ,can I buy just a new gasket ? Canadian tire was telling me I have to get a new WP and they dont sell gasket material or just gaskets.
Im also pretty poor so If I dont have to replace it I would rather not.
Thanks Tons
Bean
Edit- Sorry I posted this in the wronge forum
bboybean is offline
post #2 of 8 Old 05-27-2008, 09:51 AM
XJohnnyC
XJohnnyC's Avatar
I don't even use a gasket on my water pump. Just RTV. "The Right Stuff" works well too.
XJohnnyC is offline
post #3 of 8 Old 05-27-2008, 08:27 PM Thread Starter
bboybean
Yeah a couple people said the same thing. Ill try it, thanks for the help.
bboybean is offline
post #4 of 8 Old 05-27-2008, 08:28 PM
jeepicon-com
let know how it works out for ya!
jeepicon-com is offline
post #5 of 8 Old 05-28-2008, 04:22 AM
Comanche5L
your positive the pump isnt gone? it would be a good time to replace it if it is. mine started spraying fluid and the pump was toast
'88 Comanche, '01 front clip, Mustang 5L, T-5 & Tonns of unnecessary noise
'91 Comanche, '01 front clip, I6 H.O, RE 3.5" Superflex
'91 CJ'd Sahara 4L
Comanche5L is offline
post #6 of 8 Old 05-28-2008, 01:29 PM
Abstruse
Even if I was very poor I think I'd still replace the water pump if I was going to take it off. Beats having to deal with it going out on you later, likely at the worst possible moment. Anytime I've ever seen leaking from that area its always been from a bad water pump, its usually actually leaking out of the small weep or vent hole on the pump body.
RTV does work great, often better than an actual gasket, its just a little messier next time you have to go and replace what ever part your sealing up with it. Let the stuff set up, at least 24 hours if you can wait that long before putting coolant back in the system. I've been in situations where I've had to use RTV and then immediately go without waiting for it to set up and its worked, but its best in the long run to allow it as much time as possible to cure.
Abstruse is offline
post #7 of 8 Old 05-31-2008, 10:40 AM
bryans98tj
I too would replace the pump. You have to pull it all apart anyways and how much would it suck to find out that it was not the gasket after all but actually the pump. I consider it maintenance.
Do it right or do it twice.
98 TJ-bought-not built
كافر - Infidel
bryans98tj is offline
post #8 of 8 Old 06-05-2008, 09:54 PM Thread Starter
bboybean
Thanks all for the replies, Ill let you guys know how it goes. I bought a new WP too just in case, like you guys said at least then ill be confident it wont go anytime soon.
bboybean is offline
water pump gasket - dry or RTV? redsoxski XJ Cherokee Technical Forum 12 03-14-2010 01:29 AM
Leak located at water pump - replaced pump- still leaking natesxj XJ Cherokee Technical Forum 11 11-02-2009 08:06 PM
Water pump? Direct OR reverse flow pump? husker25 XJ Cherokee Technical Forum 0 03-22-2005 09:41 AM
Water pump gasket leaking, I think XJ-NoDough XJ Cherokee Technical Forum 2 02-04-2005 09:16 PM
Cooling system checklist (water pump/ head gasket tests as well). balloo93 XJ Cherokee Technical Forum 0 10-19-2004 11:15 AM
