Vacume leak detection (how can I do it) - JeepForum.com
post #1 of 4 Old 03-07-2008, 11:56 AM Thread Starter
wranglercory
I was wondering if there is a good way to track down a vacume leak. I've heard that you can use starter fluid to spray lightly around the hoses and if the idle goes up there may be a vacume leak. Does anyone have any other sugestions about how to do this . I am having a little problem with a slightly higher idle than what I think is normal. It is running around 12-1500 even after it warms up . I have swaped the IAC with a Junk yard one and that the next day later made it worse then I swapped it back and it brought it back down to 12-1500 . I havent tried the TB cleaner yet but may do that soon .
Addicted to Jeeps , had 1994 YJ, &1994 XJ, Have now 1997 XJ, 1996 XJ, &my project 1989 MJ, just bought another 89 MJ with a 4 cyl.
wranglercory is offline
post #2 of 4 Old 03-07-2008, 03:25 PM
maddzz
1989 MJ Comanche
You can buy new lines from napa. There are two main pieces for $20 each. And then the small fitting and line that comes off the back of the valve cover is about $10. These are the part #s
715-1367
715-1366
715-1365
maddzz is offline
post #3 of 4 Old 03-13-2008, 11:34 PM
carnuck
1984 J-Series Truck
too much ether can melt the pistons!
carnuck is offline
post #4 of 4 Old 03-19-2008, 03:19 PM
rnuover
First turn ur jeep on then take a propane tourch and turn the gas on, dont light it. Just pass the tourch over all of the vacum lines. When you hear the engine rev that is where your leak will be.
Hope this helps
2000 WJ stock
*Stolen*
1992 Jeep Cherokee, 4.5in Rough Country lift, Bushwacker Fender Flares, Homemade Bumpers Front and Rear, 33x12.50 TSL's, Flowmaster 40 Series Muffler.
rnuover is offline
P1494 - Leak Detection Pump Location xjRalfy XJ Cherokee Technical Forum 8 08-19-2016 11:06 PM
exhaust leak detection? beater_xj XJ Cherokee Technical Forum 1 08-03-2008 01:45 PM
Vaccuum Leak Detection? Idle Issue? 4.0H.O.XJ XJ Cherokee Technical Forum 1 05-16-2007 08:04 PM
Leak Detection Pump and other things BDJCL3 XJ Cherokee Technical Forum 1 10-05-2006 09:58 AM
Leak detection pump - is it supposed to tick? jgenova02 XJ Cherokee Technical Forum 1 03-13-2005 12:08 PM
