v8 comanche - Page 4 - JeepForum.com
post #46 of 58 Old 08-23-2006, 07:34 PM
eclipse27
Originally Posted by DirtyCommanche
The 8.8 is a very easy swap. I'm getting ready to swap mine into my XJ. It was in my MJ before! Just weld the spring perches and shock mounts on (or booty fab 'em), new ubolts, and run two passenger side brake hoses and some new lines and it's all good. Wheel spacers probably will be needed.
And the truck avenger is a good carb, but for offroad use it still doesn't compare to EFI or propane. Even though it is designed to work off-camber, it is certainly not optimal in those situations... (Although, I saw a truck with one idle fine while upside down.)
what do you mean by "booty fab'em"
eclipse27 is offline
post #47 of 58 Old 08-23-2006, 09:30 PM
DirtyCommanche
I used my old top plates and an extra set of u-bolts... I cut the top plates to fit the radius of the axle, then cranked down the u-bolts once I had them in the position I wanted them. The top plates have shock mounts on them.
DirtyCommanche is offline
post #48 of 58 Old 08-30-2006, 03:56 AM
Mr Q X
Mr Q X's Avatar
you should race a vette that would be soooooooooooo cooooooooool.
Mr Q X is offline
post #49 of 58 Old 08-30-2006, 08:21 AM Thread Starter
S10Eater
S10Eater's Avatar
if your aiming that at me...my dad has a '79 vette and my truck seems to perform better than it... as for a new vette i have to get new rearend and gears first. i will (not might) i will beat a new vette to approx 150km/h or about 95mph at which point i run out of gearing and engine and the vette will take over.
1987 350 JEEP COMANCHE
Licence plate: FSTJEEP
2001 TJ SE, 31" KM2s, cragar d styles
JEEP: If i wanted a Hummer, I would have asked your sister
S10Eater is offline
post #50 of 58 Old 09-23-2006, 10:59 PM
bigjohnson69
Ugh, hadn't bothered to read this thread.
Everyone who thinks the AMC 4.0 is all that - f' off. Yeah, it's a great truck/wheeling engine for it's low end grunt and realiability. It is NOT a performance engine and NEVER will be. I think Dino's numbers are out-to-lunch, based on my own experience in the area. He did a lot of guessing, and buying into advertisment BS. Oh, and a 4.0 weighs as much as a BBC!
A Chevy V8 is THE cheapest engine to get power out of. That crate engine is dyno gaurenteed (IIRC) and for a good reason. Not to mention it has a factory warranty. Also, as is the nature of USEABLE power, the torque curve (and HP) curve of the chevy engine will be far more usable for a street application.
Also, it's generally better (in the long run) to not be trying to get an insane amount of power out of an engine for its size. It's a longevity thing.
Anyways, S-10 eater, looks damn nice! If I was building a street truck I know it'd be powered by something like that. And carbs are great for street applications - but they blow off-road.
No it doesnt
Plus, are you gonna put a BBC in ur jeep? Well, if you do, I want pictures lol
bigjohnson69 is offline
post #51 of 58 Old 09-24-2006, 11:44 AM
Country Jeep
Comanche Kemosabe
Country Jeep's Avatar
Originally Posted by bigjohnson69
No it doesnt
I'd like to see some figures that you're basing your statement on. As far as I know, they do weigh the same.
Main rig under screen-name...
, 4.0L HO I6, AW4. Daily driver.
'98 XJ Classic (moss green) 2WD, 4.0L HO I6, AW4. Restoration project.
Gone, but not forgotten:
, '94 ZJ Limited, '85 CJ7,
Blue Jeep Club Member #113
Country Jeep is offline
post #52 of 58 Old 09-24-2006, 02:26 PM
98XJ-ID
98XJ-ID's Avatar
what size shoes u run in the rear of that thing? i'd love to see more pics, good work.
1990 Jeep Comanche Pioneer 4x4
4.0L - D30/D35 - 5-Speed - NP231- 130K
1998 Jeep Cherokee Classic 4x4
4.0L - D30/Corp 8.25 LSD - NV242 From a 2002 Grand Cherokee - 4" Suspension/31's - 136K
98XJ-ID is offline
post #53 of 58 Old 08-05-2012, 02:54 PM
forkliftguy
You did a nice job, looks clean. What tranny did you use?
Can u add more pics?
forkliftguy is offline
post #54 of 58 Old 08-16-2012, 11:37 AM
balzer
From all the info I can gather the 4.0 actually weighs MORE than a BBC by 15-20 lbs in long block form.
The 4.0 is a decent engine dont get me wrong, but it doesn't hold a candle to a small block chevy V8. There is NO cheaper way to build a performance engine than to start with a small block GM. And as far as performance goes the 4.0 is a tractor engine its just not going to be a high performance engine.
2001 TJ SE
1971 J4800 gladiator
balzer is offline
post #55 of 58 Old 08-16-2012, 12:00 PM
97_4popper
1990 MJ Comanche
holy old post batman!
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
Check out comancheclub.com...
My build thread:
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline
post #56 of 58 Old 08-16-2012, 01:10 PM
balzer
Yea its like 2 weeks old wow! f it was a house fly it would be dead by now thanks for pointing that out!
2001 TJ SE
balzer is offline
post #57 of 58 Old 08-16-2012, 01:19 PM
LimeLJ
LimeLJ's Avatar
Originally Posted by balzer View Post
yea its like 2 weeks old wow! F it was a house fly it would be dead by now thanks for pointing that out!
2006.
LimeLJ is offline
post #58 of 58 Old 08-16-2012, 01:34 PM
balzer
Yes I am aware of that but you might notice the last convo was 2 weeks ago and still had incorrect info. Even old bad info needs corrected
2001 TJ SE
balzer is offline
No more oil under Comanche now PitBull4X4 MJ Comanche Technical Forum 0 07-28-2009 12:26 AM
86 Comanche yerington06 MJ Comanche Technical Forum 3 05-04-2008 01:15 AM
Looking for another Comanche '88 Red Devil MJ Comanche Technical Forum 7 04-12-2008 05:01 PM
Here's my Comanche Country Jeep XJ Cherokee Technical Forum 4 10-26-2004 08:25 AM
Comanche V8 JERSEYJOE XJ Cherokee Technical Forum 1 10-01-2004 05:58 PM
