Trouble with the Comanche! - JeepForum.com
post #1 of 3 Old 06-26-2013, 03:46 PM Thread Starter
parkia86
1987 MJ Comanche
To get started I have an 87 Jeep Comanche Laredo with the 4.0L engine and 4x4. The transmission is the 3 speed auto.
This morning the Comanche started up fine but about 2 minutes into the drive she just stalled out. This has happened before and I just put it in park and she fired right up. About 6 hours later I was going to lunch and she would not start. The engine was cranking and she would sputter a bit as if she wanted to start but she wouldn't. After about 10 min I sprayed some starter fluid into the intake, she didn't start the first time but after several tries and putting starter fluid in the intake she fired up and I got her home. This is the second time she has done this and now I fear it's permanent, a few hours after getting home I tried again and she still failed.
Work to date:
I replaced the fuel injectors and the air throttle valve about 1.5 years ago.
I do not remember the last time I did plugs and wires and distro cap.
Replaced all of the engine bay vacuum lines.
The battery is less than 2 weeks old.
Fuel filter was replaced 3 yrs ago.
Odd symptoms:
I hear a strange buzzing/hissing coming from the vicinity of the fuel pump(assuming its the circular thing on the fuel tank). I put my hands on the vacuum lines in the area and could not detect a leak. I had the car in a garage this winter and prior to taking it out I have never heard that sound from the fuel tank.
Spraying carb cleaner will eventually get her started but takes multiple attempts.
If the engine is warm she will start.
Please help! I'd love to fix her this weekend
parkia86 is offline
post #2 of 3 Old 06-27-2013, 06:18 AM
zackcj7
Fuel pump is going out. Pretty common problem on the Comanches. When they start to get loud it's a sure sign it's about to die.
It's not too bad of a job to replace. Pull the rear driveshaft for access, some people remove the tank some don't. I recommend the Bosch turbine style replacement pump.
Check out comancheclub.com if you haven't already.
zackcj7 is offline
post #3 of 3 Old 06-27-2013, 04:20 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Good idea. And replace the filter at the same time.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
