Transmission not staying in gear, cant shift into gear - JeepForum.com
post #1 of 5 Old 10-06-2009, 03:07 PM Thread Starter
Jakeman17
1988 MJ Comanche
I have a 88 Comanche 5-speed Manual and something mainly on cold starts I will not be able to **** into second it will grind but it will go into 3rd 4th and 5th with no problem. also if i am going over 10MPH I cant not put it into 2nd bc it will grind. It will also pop out of gear occasionally. and also be hard to get into gear.
While letting out the clutch minly on cold starts it seems to shift really hard.
What do you think?
I have been told pressure plate, clutch
'88 Green Jeep Comanche
Jakeman17 is offline
post #2 of 5 Old 10-06-2009, 08:02 PM
Youngelliott
I am also having the same problem with my 88 YJ. It only does it in reverse though. It pops out unless I hold it in.I would like to see if you get a response.
Thank You
Jason
Youngelliott is offline
post #3 of 5 Old 10-06-2009, 10:05 PM
1984XJ
What do you think?
Try this place, Its a better MJ sight
ComancheClub.com • Index page
.,_______.o_o.
//_|__l__,\___\,___
l_--\__\__l----[]llllll[]
_(o)_)____(o)_)--o)_)
Daily Driver Jeep #16
Utah Jeep'n
1984XJ is offline
post #4 of 5 Old 10-10-2009, 03:22 AM
Abstruse
Its a known issue with your transmission, if you google search upgrade parts for it you'll find some fixes.
Abstruse is offline
post #5 of 5 Old 02-08-2010, 11:51 AM Thread Starter
Jakeman17
1988 MJ Comanche
I upgraded to a AX-15 for the 4X4 Conversion
No problems anymore
Cold transmission wont shift out of 1st gear sAe23 XJ Cherokee Technical Forum 38 07-01-2013 06:51 PM
Transmission acts like it won't shift out of 4th gear 53case MJ Comanche Technical Forum 0 11-01-2009 09:52 AM
1991 transmission wont shift in proper gear corbin9191 XJ Cherokee Technical Forum 6 01-27-2009 11:11 AM
Can't shift into gear..help cobra XJ Cherokee Technical Forum 8 12-02-2007 09:20 PM
need help: can't shift into any gear ksudar XJ Cherokee Technical Forum 11 09-01-2005 02:23 PM
