Transmission Case - JeepForum.com
post #1 of 1 Old 04-07-2012, 07:37 PM Thread Starter
314atk
1989 MJ Comanche
Transmission Case
Hey,
New member i picked up and 89 MJ for $50 couldnt pass it up. It has an ax-15 tranny in it which needs to be replaced, i received an extra tranny which i was told was good but has a 4 inch crack in the housing. I am planning just swapping the housing piece that is crack with the housing piece from the bad tranny, from looking at it im hoping it is as simple as just bolting the casing half i need on but before i started i want to know if anyone has done it and can tell me if it is more technical than that
Thanks in advance
314atk is offline
Transmission/transfer case thedcorvette XJ Cherokee Technical Forum 3 05-02-2011 09:55 AM
transfer case or transmission chiefart XJ Cherokee Technical Forum 5 08-04-2006 05:44 PM
tranfer case or transmission? chiefart XJ Cherokee Technical Forum 4 07-22-2006 08:32 PM
New ? Transmission and transfer case lrsmithwhaley XJ Cherokee Technical Forum 1 12-26-2005 12:35 PM
transfer case/transmission charlie_merrifi XJ Cherokee Technical Forum 4 01-22-2005 10:22 AM
