Transmission acts like it won't shift out of 4th gear - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > MJ Comanche Technical Forum > Transmission acts like it won't shift out of 4th gear
Get 5% Back On Rugged Ridge-Omix-ADA-Alloy at ExtremeTerraGibson Exhaust Rebate - ExtremeTerrain!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 11-01-2009, 10:52 AM   #1
53case
1990 MJ Comanche
I have a 1990 Comanche that starts fine but the transmission acts like it wont down shift. It has no low end pick up & I get a growling noise when I step on the gas, it acts like it is stuck in 4th gear. I have changed the filter and added new fluid that didn't make a difference. Could it be the solenoids or the torque converter?
53case is offline   Reply With Quote Quick reply to this message
