Transmission acts like it won't shift out of 4th gear - JeepForum.com
post #1 of 1 Old 11-01-2009, 09:52 AM Thread Starter
53case
1990 MJ Comanche
I have a 1990 Comanche that starts fine but the transmission acts like it wont down shift. It has no low end pick up & I get a growling noise when I step on the gas, it acts like it is stuck in 4th gear. I have changed the filter and added new fluid that didn't make a difference. Could it be the solenoids or the torque converter?
53case is offline
Cold transmission wont shift out of 1st gear sAe23 XJ Cherokee Technical Forum 38 07-01-2013 06:51 PM
Transmission not staying in gear, cant shift into gear Jakeman17 MJ Comanche Technical Forum 4 02-08-2010 11:51 AM
Transmission won't shift in 'D'.. funnynyck XJ Cherokee Technical Forum 16 06-16-2009 02:23 PM
1991 transmission wont shift in proper gear corbin9191 XJ Cherokee Technical Forum 6 01-27-2009 11:11 AM
Transmission whine on manual transmission 2nd gear Hubbazoot XJ Cherokee Technical Forum 2 11-23-2008 01:30 AM
