Transmission - Page 2 - JeepForum.com
post #16 of 22 Old 03-06-2012, 08:57 PM
tbburg
You might want to do some more diagnostics before doing your swap. (Bear with me here.)
The AW-4 (all years) is an electric controlled transmission. Without the functioning transmission control electronics, a brand new transmission won't shift properly. I want to say the manual mode for the AW-4 is, 1,3,4 & R, no torque converter lockup, no second gear, no automatic function.(That's from memory, not the FSM)
From what you're describing, it sounds more like an electronic failure then a mechanical failure. If that's the case, changing the transmission won't fix the problem. As it all died at once, I'd look at the TCU, wiring harness, and plugs at the transmission before I pulled the trans. Unlikely to have both shift solenoids blow at the same time. Also check for power to the TCU. In the 96-back models, the trans system is on a separate harness, and doesn't "talk" to the engine control computer.
"Never attribute to malice that which can be adequately explained by stupidity, but don't rule out malice."
My other car is also a Jeep,.. and so is the other one,.. and that one too. How many do you own before it's "a herd" ?
tbburg is offline
post #17 of 22 Old 03-12-2012, 07:51 PM Thread Starter
ctm9191
1989 MJ Comanche
sorry for the delay in responding, had some family matters to deal with, you guys were right, tcm for $10 at the pick and pull fixed the problems. thank you guys so much for your help and for saving me the $ for a worthless tranny. about made a huge mistake there
Originally Posted by NHRubi View Post
It's a broken kanibulen pin in your flux capacitor, take your rig off the street immediately
ctm9191 is offline
post #18 of 22 Old 03-12-2012, 08:28 PM
BigRedWilkey
I'm having the Sam exact problems. I can't seem to find a tcm. Does anyone know where I could get one?
BigRedWilkey is offline
post #19 of 22 Old 03-12-2012, 08:30 PM
BigRedWilkey
Does anyone know where I can get a tcm?
post #20 of 22 Old 03-13-2012, 05:51 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
From Joe Peters and well stated:
“Let’s play a game.
You pretend that you are the only one that knows what year/engine, etc that you are asking about.
We will all pretend you never asked a question until you provide at least the bare minimum of information about your vehicle”.
cruiser54 is offline
post #21 of 22 Old 03-13-2012, 09:07 AM
BigRedWilkey
Sorry about that. 1990 4wd with the 4.0 it's an automatic
post #22 of 22 Old 03-14-2012, 07:58 AM Thread Starter
ctm9191
1989 MJ Comanche
At almost every junkyard. Always remember, no distance is too far to fix your Jeep
ctm9191 is offline
Transmission Line Leaking at Transmission keaton XJ Cherokee Technical Forum 0 09-18-2011 09:46 PM
transmission help Saint18z XJ Cherokee Technical Forum 4 03-01-2010 04:55 PM
Transmission whine on manual transmission 2nd gear Hubbazoot XJ Cherokee Technical Forum 2 11-23-2008 01:30 AM
Transmission help MUDBOG101 XJ Cherokee Technical Forum 23 12-16-2007 03:41 PM
strange engine/transmission noise and oil leaking from transmission? weldmaster4000 XJ Cherokee Technical Forum 5 04-20-2006 01:06 PM
