Transmission - JeepForum.com
post #1 of 22 Old 02-21-2012, 08:30 PM Thread Starter
ctm9191
1989 MJ Comanche
Transmission
I have an 89 MJ poineer 4.0 automatic and it decided it is done shifting on its own, also seems to have lost overdrive, all parts stores i have contacted have said a rebuild kit is going to run between 4-500 so i am going to take my chances with a scrap yard tranny. Does anyone know if i can use any cherokee tranny or does it have to be from a renix cherokee/comanche. any and all help is appriciated, especially if someone might know what may actually be bad with my current pissed off transmission.
Originally Posted by NHRubi View Post
It's a broken kanibulen pin in your flux capacitor, take your rig off the street immediately
ctm9191 is offline
post #2 of 22 Old 02-22-2012, 04:52 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Explain "shifting on it's own". This could be as simple as a blown fuse.
cruiser54 is offline
post #3 of 22 Old 02-22-2012, 07:08 AM
Garvin
1986 MJ Comanche
Could be a blown fuse, as cruiser54 said or could be the TCU. I don't really know too much about automatic transmissions (chose to stay away from dealing with them because they are more of a headache with all the little parts). What I can tell you is what will fit with a swap.
For a direct swap one, you will need an '87-'90 AW4. In '91, they went from a 21 spline output to a 23 spline output. The '91+ transmissions will bolt up (up to '95 will be a direct plug in) but you will need to either swap the input shaft of the transfer case to 23 spline or grab the transfer case that was attached to the transmission, which will be a 23 spline. If you decide to swap the transfer case input shaft, you will need to get one from a '91-early '94 (you'd be safer with a '91-'93 as I'm not sure on the exact cut off date). The reason for that is because they changed the planetary gears in mid '94 to a different pitch (for lack of better words) and they will not mesh with the older style.
When I did the transmission swap in my '90, I got lucky and found an early '94. I grabbed the transmission and transfer case and swapped in the input shaft into my NP231 (mine had an SYE in it already, reason I swapped the inputs over just slapping in the other transfer case).
1986 Jeep Comanche 126000+ miles
Long Bed, Chevy 350 TPI (5.7L V8), AX15, NP231
Roll Bar, 15/38.5R16.5 Ground Hawgs, Bastard lift (Custom 3-link long arm system, 4.5" Rusty's front springs w/ 1.75" spacers and 6.5" RC shocks, SOA rear), Dana 60HP/Sterling 10.25, 4.10's, Recessed winch, more mods to come...
1992 Jeep Comanche 174000+ miles
Short Bed, 4.0L I6 HO, AX15, NP231
In the process of doing a frame up restoration.
...RIP...
1990 Jeep Cherokee XJ 207774 miles
4.0L I6, AW4, NP231. Tom Woods SYE and Drive Shaft, Rusty's 8.0" Long Arm Suspension Lift, 36/13.5R15 Super Swamper IROK's, Dana 30 Front, Tube Diff Guard, Dana 44 Rear, 4.56 gears, Ox Locker, disc brake conversion
Garvin is offline
post #4 of 22 Old 02-22-2012, 07:52 PM Thread Starter
ctm9191
1989 MJ Comanche
To explain shifting on its own, when i put the truck in drive, it is in third gear, if i want it to go to first, I have to put it in 1-2 position on the shifter, If i do however, it does not go into second unless i place the shifter on "3" if I want third, I have to place it in "D". I will go out tomorrow in the day light and check all the fuses. What is the TCU? I know a good bit about the motor, just absolutly nothing on the transmission. Thank you for the help.
ctm9191 is offline
post #5 of 22 Old 02-22-2012, 07:55 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Up under the passengeer side dash, under the glovebox is the TCU aka Transmission Control Unit. It has an inline fuse going to it wrapped in the harness with yellow tape.Good chance the fuse is bad ot the fuse holder is corroded. Let us know what you find. Don't replace your trans just yet...........
post #6 of 22 Old 03-01-2012, 09:44 AM
XmuthJ
Also could be as simple as a few bad solenoids if the fuse looks okay.
|___NEW JEEP___| 87 MJ Lwb | 4.0L | ba10 | D30/D35 | NP231 |______________|
^*^*^ Waiting to go in: 94 YJ AX-15, 99 XJ NP231 (23 spline) ^*^*^
Originally Posted by FrumpD63
Had I bought that lil mazda I was looking at, they wouldnt have found my body until the spring.
XmuthJ is offline
post #7 of 22 Old 03-02-2012, 07:44 AM Thread Starter
ctm9191
1989 MJ Comanche
Tcm fuse is good. I found a 93 Tranny for $138 with a 90 day warranty. Ill pick it up and a Tcm on Monday, rebuild mine and sell the one I buy after mine is rebuilt.
ctm9191 is offline
post #8 of 22 Old 03-02-2012, 08:08 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Don't count on it fitting. The spline count between the trans and transfer case is different.
post #9 of 22 Old 03-02-2012, 10:57 PM
chromegrille
1947 CJ2A
most likely your transmission is okay; it's shifting in manual mode like it should.
chromegrille is offline
post #10 of 22 Old 03-03-2012, 05:52 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I think it's a very hasty decision to replace the trans, especially with one that won't fit. Gotta be electrical.
post #11 of 22 Old 03-04-2012, 12:27 AM Thread Starter
ctm9191
1989 MJ Comanche
well with the size of metal shards in the pan when i changed the filter, i was thinking i lost overdrive and it was causeing the others to go out.
ctm9191 is offline
post #12 of 22 Old 03-04-2012, 04:38 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Nice details to leave out of your first post.
post #13 of 22 Old 03-04-2012, 04:31 PM Thread Starter
ctm9191
1989 MJ Comanche
With the first post I had not done the fluid yet
ctm9191 is offline
post #14 of 22 Old 03-04-2012, 06:35 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Just sayin'. ...At which post had you done the fluid and not included that info?
post #15 of 22 Old 03-04-2012, 10:24 PM Thread Starter
ctm9191
1989 MJ Comanche
this one, i had done the fluid change that day and called around to find a transmission, my I applogize for the confusion, tomorrow I will be heading to pick up the tranny and t-case along with a few other needed parts like, a speedometer cable (been over a year since i had a proper one)
ctm9191 is offline
Transmission Line Leaking at Transmission keaton XJ Cherokee Technical Forum 0 09-18-2011 09:46 PM
transmission help Saint18z XJ Cherokee Technical Forum 4 03-01-2010 04:55 PM
Transmission whine on manual transmission 2nd gear Hubbazoot XJ Cherokee Technical Forum 2 11-23-2008 01:30 AM
Transmission help MUDBOG101 XJ Cherokee Technical Forum 23 12-16-2007 03:41 PM
strange engine/transmission noise and oil leaking from transmission? weldmaster4000 XJ Cherokee Technical Forum 5 04-20-2006 01:06 PM
