Which trans? - Page 2 - JeepForum.com
post #16 of 22 Old 08-19-2013, 09:42 PM
Rican142
Ahhh, yeah I wish I had the money to get a new trans in the mj
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #17 of 22 Old 08-19-2013, 11:48 PM Thread Starter
BrandonYJReed
2016 JK Wrangler
You can pick up ax15's fairly cheap... But thanks for all your advice and info! But can anyone else back this up? Is the ax15 a direct swap? It the t-case the same spline and everything? I just want a second opinion. Thanks.
'16 JK Sport
-2.5" TF Spring Lift
-315 BFG A/T
-3.73
BrandonYJReed is offline
post #18 of 22 Old 08-20-2013, 12:06 AM
Rican142
Do a could searches on here, I know theirs gotta be a bunch of threads on here
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #19 of 22 Old 08-20-2013, 12:08 AM Thread Starter
BrandonYJReed
2016 JK Wrangler
Will do. Thanks again Rican!
'16 JK Sport
-315 BFG A/T
-3.73
post #20 of 22 Old 08-20-2013, 12:22 AM
Rican142
No problem, thanks for asking a question I can actually help with lol, good luck!
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #21 of 22 Old 08-27-2013, 09:19 AM
dkroll
1988 MJ Comanche
You mentioned a transfer case, if this is a 4x4? Novack has a bunch of good info on spline and compatibility. I had a AX15 swap done on my 2 wheel drive and I am very happy with it!
Doug
dkroll is offline
post #22 of 22 Old 09-16-2013, 08:31 PM
87MJTim
1987 MJ Comanche
No, the spline counts are diff.
You will need the tcase that goes with the AX15 (23 splines).
The BA10 has 21 splines.
87MJTim is offline
