Which trans? - JeepForum.com
post #1 of 22 Old 08-18-2013, 09:47 PM Thread Starter
BrandonYJReed
2016 JK Wrangler
Which trans?
I have a 89 MJ and it has a 5 speed. I'm not sure of its has the ba-10 or the ax-15. How can I tell the difference?
'16 JK Sport
-2.5" TF Spring Lift
-315 BFG A/T
-3.73
BrandonYJReed is offline
post #2 of 22 Old 08-18-2013, 10:16 PM
Rican142
I went through the same thing haha, the ba10 has a split transfer case, you can see the seam right down the middle, and it's also relatively small
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #3 of 22 Old 08-18-2013, 10:19 PM Thread Starter
BrandonYJReed
2016 JK Wrangler
thankyou but that just doesn't help much, is there any better way to i.d. it?
'16 JK Sport
-315 BFG A/T
-3.73
post #4 of 22 Old 08-18-2013, 10:58 PM
Rican142
Ba10 on left, aisin on right notice the seam on the case
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #5 of 22 Old 08-18-2013, 10:59 PM
Rican142
Aisin on left this time
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #6 of 22 Old 08-18-2013, 11:00 PM
Rican142
Other than that, idk of any I.d tags on em
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #7 of 22 Old 08-18-2013, 11:06 PM Thread Starter
BrandonYJReed
2016 JK Wrangler
I think that will help a lot. thanks!
'16 JK Sport
-315 BFG A/T
-3.73
post #8 of 22 Old 08-18-2013, 11:12 PM
Rican142
And if you really need it, I'll take a pic of the ba10 in my comanche so you can see
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #9 of 22 Old 08-18-2013, 11:21 PM Thread Starter
BrandonYJReed
2016 JK Wrangler
I should be alright. And are they internal or external slaves?
'16 JK Sport
-315 BFG A/T
-3.73
post #10 of 22 Old 08-19-2013, 12:37 AM
Rican142
Just one internal, and it's a pain to replace, it's within the bell housing (11 bolts to seperate the bell housing from the motor) it's on the drivers side
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #11 of 22 Old 08-19-2013, 06:16 AM Thread Starter
BrandonYJReed
2016 JK Wrangler
So what would be involved in swapping from the ba/10 to ax-15?
'16 JK Sport
-315 BFG A/T
-3.73
post #12 of 22 Old 08-19-2013, 08:26 AM
Rican142
From what I've heard, I think it's a direct fit. But the ba10 (though it's kinda crappy) if you take care of it it'll treat u well, I haven't had any problems with mine knock on wood
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #13 of 22 Old 08-19-2013, 08:29 AM
Rican142
And the ba10 is easier to drop if you doin the work on the ground. Just cause it's smaller and lighter(only plus)
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #14 of 22 Old 08-19-2013, 08:30 AM
Rican142
I would get ahold of the ax15 and just hold on to it, tear up the ba10 then when it finally gives, just swap it out
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #15 of 22 Old 08-19-2013, 01:34 PM Thread Starter
BrandonYJReed
2016 JK Wrangler
I have a ax-15 laying around already, and my ba10 doesn't like to shift into 2nd gear all that well anymore.
'16 JK Sport
-315 BFG A/T
-3.73
