tranny swap for a 86 - JeepForum.com
post #1 of 8 Old 02-17-2005, 07:44 PM Thread Starter
1986 mj
i was wondering if any one would know what it would take to upgrade the transmission in a 86 from a 3 speed to a 4speed automatic any info will be greatly apreciated oh yeah it is the gm 2.8 v 6
1986 mj
2.8 v6 automatic 4x4
bed mounted roll bar
and lots more to come
1986 mj is offline
post #2 of 8 Old 02-17-2005, 11:31 PM
1986Comanche
1986 MJ Comanche
I don't know of any 4 speed automatic transmission that will fit on a 2.8L V6 in a Comanche. The only thing you could change to is a AX-5 5 speed manual transmission. Will have to be out of a 4X4 Cherokee or Comanche since yours is 4X4. Would have to be out of one with a 2.5L 4 cylinder or a 2.8L V6. Would be alot of work going from an automatic to a manual transmission though. Have to put the pedals in and everything. Why are you interested in upgrading other than the automatic is only a 3 speed with no overdrive?
1986 Jeep Comanche 4x2, 2.5L I-4 TBI, 4 Speed
Blue Jeep Club Member #123
Easy to be a truck. Hard to be a Jeep.
1986Comanche is offline
post #3 of 8 Old 02-18-2005, 07:12 AM
BRC 88MJ
As the 2.8L is the same motor that GM offered in the S-series trucks and SUVs, the 700-R4 trannies that were offered in those vehicle should bolt right behind your motor. I'm not entirely sure of all of the electrical and transfer case adaptations that you may have to do. HTH.
Brent
BRC 88MJ is offline
post #4 of 8 Old 02-18-2005, 02:48 PM Thread Starter
1986 mj
thanks for the input i know it was never ment to be a race car but when pulling my little boat or making any trip down the highway it really inhales gas and rpms at 70 run about 4ooo so basicly wanting an extra gear plus i got spoiled in the manche i had before this one it was a 89 4.o liter 5 speed manual but only 2 wheel drive. and for what it was going to cost for me to replace the slave cylinder i was able to buy my current manche less than fixing the other one of course i got the current one for 100 dollars
1986 mj
1986 mj is offline
post #5 of 8 Old 02-18-2005, 02:57 PM
1986Comanche
1986 MJ Comanche
BRC 88MJ, yeah you could possibly swap in a newer transmission, but the transmission mounts and everything will be different I'm sure. Would be alot of work.
post #6 of 8 Old 02-21-2005, 06:29 AM
BRC 88MJ
If he wants to swap from a 3-speed to a 4 speed, the tranny itself will be longer anyways. Modifications will have to be done in order to make a 4-speed fit where a 3-speed originally was mounted. It wouldn't require much fabrication to either adapt his current crossmember or use one from an AW-4 equipped or 5-speed MJ and modify it.
Also, in 1986 those transmissions weren't computer controlled. The only electrical connection required was for the lock-up funtion on the torque converter. B&M, TCI and Painless Performance all make kits for this. The TV cable for the transmission would be the only potentially big problem I see. You would have to fab up a mount that would give the TV cable the proper adjustment or risk burning up your transmission.
BRC 88MJ is offline
post #7 of 8 Old 02-21-2005, 07:05 AM
1986Comanche
1986 MJ Comanche
I don't think its worth all the work anyway. Give me a manual transmission over an automatic any day.
post #8 of 8 Old 02-21-2005, 10:28 AM
BRC 88MJ
Perfhaps not worth the work (I prefer manuals, too). But the swap is definitely doable.
BRC 88MJ is offline
Tranny swap ?s: AW4 to AX15 swap (or any other trannies for that matter)... Bryson XJ Cherokee Technical Forum 8 06-22-2009 02:01 AM
XJ Tranny Swap BeerDonor XJ Cherokee Technical Forum 3 12-16-2007 01:12 PM
91 Tranny Swap? Rwork MJ Comanche Technical Forum 2 08-13-2007 08:00 AM
Tranny Swap xjguy98 XJ Cherokee Technical Forum 5 01-09-2006 06:48 PM
XJ tranny swap NeillBarber XJ Cherokee Technical Forum 2 04-03-2002 09:18 PM
