I have a an 86 comanche with a 2.5 litre with a five speed that i think is a T5 or did they come with another 5 speed in 86?
Yes, there are a lot of errors, but good pics.Pete M said:Dang, there are sooooooooo many errors on that site. Pictures seem good though.
The Ba-10 will only bolt to the 4.0/4.2 so it's not that. Both the T5 and Ax-5 were used pre-87 but the info becomes sketchy as to a pattern of use (2.5L/2.8L, 2wd/4wd).
car-part.com might be of some help if you're looking for another trans.
Jeep on!
--Pete
ComancheClub.com
I think you just don't know what you're talking about and you don't know what transmission you have. I have never seen a Cherokee or Comanche with a T-5 (5 speed) transmission in it. The only 5 speed transmission they offered with the 2.5L I-4 was the AX-5.CanadianJeep86 said:Strange, because I have an '86 Comanche long bed, 2.5L with the T-5 Borg Warner in it.
or maybe I'm just imagining things, lol
Not trying to be rude in any way but just because you haven't seen one doesn't mean they don't exist. theres lots of things about jeeps I didn't think was true till I started coming to this site. I'm not sure if its the original one or not, I doubt it is though because the PO did the clutch in it right before I bought it.1986Comanche said:I think you just don't know what you're talking about and you don't know what transmission you have. I have never seen a Cherokee or Comanche with a T-5 (5 speed) transmission in it. The only 5 speed transmission they offered with the 2.5L I-4 was the AX-5.
Just for your information, They never offered a 4 speed with the 2.8L V6. They had 2 transmissions for the 2.8L V6. The 5 speed manual and the 3 speed automatic. Thats it. So either you have a 5 speed and don't know it and you have the wrong shifter knob or a previous owner put the 4 speed in it which came from one with a 2.5L I-4. They only used the 2.8L V6 in the Comanche one year. The first year of the Comanche which is 1986.zoman said:well, i have a 86 'manche w/ a gm 173cid/2.8L V6 and a four speed, don't know if it's a T-4 or AX-4...but who cares? Wish it had a five speed though...gas prices suck!!
I would say the strength of them is about the same. I would guess one of the previous owners put the 4 speed in it when the 5 speed went bad because they couldn't find a 5 speed or they ran across a 4 speed cheap. What is the first 5 characters of your VIN? If you have a 4x4 Comanche with the 2.8L V6 and it originally had a 5 speed. Your VIN should read 1JTWL. The L at the end is the VIN code for the 5 speed for the 4x4. If you have a 4x2 Comanche that had a 5 speed originally it should read 1JTWW. The W is the VIN code for the 5 speed for the 4x2. Now if your truck had a 4 speed with the 2.8L V6 originally (which is not possible because they never made them) and is a 4x4 the VIN would read 1JTWX and if it was 4x2 with a 4 speed it would read 1JTWS. Hope this info helps.zoman said:rats!!! someone's messed with it before me....why swap a 5speed for a 4speed? Is the 4speed stronger???
If it was me I would look for a good 5 speed and swap the 4 speed out for the original 5 speed. I think they never offered the 4 speed with the 2.8L V6 because it is so low geared and the V6 would be really wound up at highway speeds. I know my 2.5L I-4 is wound up on the highway with the 4 speed which came factory in mine. It also depends on your rearend gear ratio too. The 5 speed has alot better ratio for the highway and the 5th gear helps a lot. Is your Comanche 4x4 or 4x2?zoman said:Yep, checked the VIN and my truck was originally equipped w/ a 5-speed tranny...you think it's worth it to find a five speed for it and swap the 4-speed for it?? How about a more modern one, say out of an XJ or the like?? Which 5-speed trannies of what year will work on my 'manche??
