Track bar removal help - JeepForum.com
post #1 of 14 Old 01-31-2012, 02:03 PM Thread Starter
gatorhead
1989 MJ Comanche
I feel like my expertise would allow me to easily romeve this item, and I can't quite remember because it has been so long ago, but I had removed it before to check the track bar due to a DW issue I was having. Fast forward to now.
The axle side came right off. Took the cotter out of the castle nut and tried to remove the other end and no dice. I tried a ball joint seperator, a BFH, crow bar you name it. The only other thing I can think of is maybe it is threaded in there?
I am trying to do it from under the truck. I have broken my neck and back so this is in no way fun lol. Replacing the suspension so I can put her on the roadside with that big orange sign. Any suggestions from here would be greatly appreciated.
gatorhead is offline
post #2 of 14 Old 01-31-2012, 03:31 PM
automan2164
1986 MJ Comanche
You sure it's not spinning in there? Do you have the nut off? If so, and it's just stuck in there, put the axle side back in, and start the truck... Steer back and fourth. Let the pressure from the steering do the work of loosening the other end for you...
Rob
'86 MJ 2.1L 4x4 MT LWB - Factory Diesel
'87 MJ 4.0L 4x2 AT LWB - Metric Ton
'97 XJ 4.0L 4x4 AT Country
automan2164 is offline
post #3 of 14 Old 01-31-2012, 03:41 PM Thread Starter
gatorhead
1989 MJ Comanche
Rob
Yeah the nut is off. The track bar is completely shot, but I will definitely try this as I have tried everything else to no avail. Thanks for the tip!
post #4 of 14 Old 01-31-2012, 03:49 PM
automan2164
1986 MJ Comanche
Yep, saw it back and fourth... Having the truck give it some business will most likely out do anything you might try by hand.
Rob
post #5 of 14 Old 02-01-2012, 09:13 AM Thread Starter
gatorhead
1989 MJ Comanche
Tried steering it back and forth and no dice!
post #6 of 14 Old 02-02-2012, 07:54 PM
ftpiercecracker
1990 MJ Comanche
The tie rod end separator you are using might be too wide, when I did mine I ran into this problem. I went and got a narrower gapped separator, soaked the crap out of the end with PB blaster, and went ape sh*t with a BFH and only then did it finally pop out.
ftpiercecracker is offline
post #7 of 14 Old 02-02-2012, 10:07 PM Thread Starter
gatorhead
1989 MJ Comanche
I have the narrower one. I cut back the bushing as much as I could and currently have it soaking in PB........Now to find a bigger BFH lol.
post #8 of 14 Old 02-02-2012, 10:30 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Get a ratcheting cargo strap. Temporarily put the bolt back in the axle end. Loop the strap over the track bar and under the axle. Tighten the strap to pull the track bar downward. Smack the piss out of the side of the track bar frame bracket with a big 2-3 lbs hammer. The vibrations will loosen the track bar.
CJ7-Tim is offline
post #9 of 14 Old 02-22-2012, 11:03 AM Thread Starter
gatorhead
1989 MJ Comanche
Figured I would update the thread. I JUST NOW got it off. I tried everything except heat. So after soaking it with PB Blaster and trying to knock it out with a 12 lb sledge I decided to try heat. I heated up the drag link on the outside and then briefly around the stud and then back outside. It took one tiny pop with a small framing hammer and it came right out. So..........
IF YOU'RE TRACK BAR IS STUCK IN THE DRAG LINK USE HEAT!
post #10 of 14 Old 02-23-2012, 11:04 AM Thread Starter
gatorhead
1989 MJ Comanche
I tried several different sizes and was crushing it with a sledge hammer and had no results other than bending the forks. I have a very bad neck and back thats why it took me sooo long. I would get up the muster and try and fail then I would have to recover. Yesterday I tried again came in and googled it again and seen someone took a torch to it. I didnt have a the big torch but I had a portable propane torch and sure enough it did the trick. Made it EXTREMELY easy.
post #11 of 14 Old 09-09-2012, 07:51 AM
stopher2
1996 FSJ Cherokee
how did you get a wrench into the bracket ? my ratchet won't even fit in there.
also, my castle has spun and the cotter is 180 degrees inconvenient ! the pull out side is on the backside of the bracket. how do i spin it to get the pin out ?
stopher2 is offline
post #12 of 14 Old 09-09-2012, 09:17 AM
ExgrayXJ
1989 XJ Cherokee
i have found it easier to just remove the frame end bracket, 4 bolts, 10 minutes (includes beer time) and gives you full access.
In my case, it was a matter of the tapered stud wasn't fully tightened due to the access problem.
Clamped in a vise, max tighten and keyed.
Re-install. Vehicle on the ground. Frame side first, axle side might require you to have someone steer it left and right to move things side to side.
All tight.
More beer time.
If it runs on gasoline count me in.
ExgrayXJ is offline
post #13 of 14 Old 09-09-2012, 12:08 PM Thread Starter
gatorhead
1989 MJ Comanche
First off I used a box end wrench, and I had to use the open end. I don't recall there being a clearance issue with it. I sold the truck so I cant go out and look to refresh my memory. I do know that I used the wrench on that. The cotter pin needs to come out before you spin it. if you have to use a pair of dykes and clip the rounded end and pull it through the end you can see/reach. Once you get it out and off you will see how to adjust it.
post #14 of 14 Old 12-23-2015, 01:38 AM
tn_outside
Heat
Old thread. But regarding heat: I just get the torch whenever I start a job on my Cherokee now. Two tool boxes, the air tools, jack stands, jack, torch. It seems nearly everything I have to break apart requires heat these days. Heat....or break things.
tn_outside is offline
Track Bar Removal optdoug XJ Cherokee Technical Forum 4 03-27-2011 08:28 AM
Track Bar Removal Chuck Cook XJ Cherokee Technical Forum 5 02-03-2008 08:44 AM
track bar removal oldjeepster XJ Cherokee Technical Forum 3 10-18-2006 08:40 PM
Track Bar Removal Steelghost XJ Cherokee Technical Forum 19 02-08-2006 12:22 PM
Track Bar removal RuffedUpXJ XJ Cherokee Technical Forum 3 12-21-2005 04:30 PM
