TJ Front Axle Assy in MJ - JeepForum.com
post #1 of 6 Old 03-21-2008, 06:40 PM Thread Starter
rubilooe
I have a D44 out of a Rubicon (front)will it fit a MJ bolt in ?Thanks
rubilooe is offline
post #2 of 6 Old 03-21-2008, 09:36 PM
jmitywhitey
1988 MJ Comanche
i think i read some were that the spring mount need to be moved
but the control arm mounts are close
jmitywhitey is offline
post #3 of 6 Old 03-22-2008, 07:50 PM
Pete M
1988 MJ Comanche
Is it a TJ Rubicon? Or the newer JK?
Jeep on!
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #4 of 6 Old 03-22-2008, 09:07 PM Thread Starter
rubilooe
Tj
Sorry , the 44 front came out of a TJ Type Thank YOU
rubilooe is offline
post #5 of 6 Old 03-23-2008, 07:42 AM
Pete M
1988 MJ Comanche
Should bolt in as far as the coil mounts, control arms, track bar, etc. Brakes changed over the years and you'll need to make sure the calipers match the rotors and such. Don't know about the driveshaft though.
Jeep on!
--Pete
My email:
Pete M is offline
post #6 of 6 Old 03-30-2008, 11:00 AM Thread Starter
rubilooe
Bolt in
Other than a driveshaft , no problems at all , I had all calipers ect... Also swap put a D44 in rear with spring over , made the rear shaft fine lift vs d44
rubilooe is offline
help replacing rear axle assy in 95 cherokee jbmcgee XJ Cherokee Technical Forum 6 05-14-2009 05:21 PM
Does the front bolt on the rear leaf assy. really screw into the frame? LUGGNUTT XJ Cherokee Technical Forum 9 01-16-2009 09:07 AM
Is it my hub assy.? rawk hard xj XJ Cherokee Technical Forum 0 02-13-2008 12:40 PM
Front hub/wheelbearing assy for 89 xj kafer1963 XJ Cherokee Technical Forum 11 11-15-2007 10:36 PM
Hub Assy jojo6714 XJ Cherokee Technical Forum 7 10-06-2005 04:28 PM
