Throw out bearing - JeepForum.com
post #1 of 4 Old 03-26-2012, 06:57 AM Thread Starter
Rican142
Throw out bearing
Whats the quickest way to got to the throw out bearing?
Rican142 is offline
post #2 of 4 Old 04-04-2012, 03:44 PM
lsmurphy
There isn't one........pull the trans.
lsmurphy is offline
post #3 of 4 Old 04-05-2012, 05:51 AM
87jeepcomanche
Yeah have to pull the trans to get to it there is no other way to get to it. But also i have read that the 2wd jeeps had a little open in the trans area to get up in there dont hold me to it but remember reading it in a manual when i had to replace my throw out bearing. But if its 4wd then ur gonna have to drop the trans and def look into a trans jack the 4wd trans with the transfer case def weighs a good amount
87jeepcomanche is offline
post #4 of 4 Old 04-06-2012, 02:19 AM Thread Starter
Rican142
Ill def check that out thanks
Rican142 is offline
Does this look right? Throw out bearing nicexj XJ Cherokee Technical Forum 4 05-20-2011 09:25 AM
Throw out bearing leaking Bastard Child XJ Cherokee Technical Forum 7 09-02-2007 10:15 PM
any tech. info. on changing rear axle bearing (pinion bearing)??????? cg2xj XJ Cherokee Technical Forum 1 07-20-2006 10:45 PM
bad throw out bearing possibly Matt1994XJ XJ Cherokee Technical Forum 3 11-09-2005 10:39 PM
Just Paid $885 for new clutch & throw bearing...... wave97 XJ Cherokee Technical Forum 1 06-10-2005 08:20 PM
