Thermostat Location for 89 Comanche - JeepForum.com
post #1 of 3 Old 03-23-2008, 01:47 PM Thread Starter
omerta1169
I have an 89 jeep comanche and can not locate where the thermostat is. I am a beginner at this so please help.
Its a 4 cylinder engine automatic.
if there is any other info needed i will apply when asked thanks in advance
Happy Easter as well
omerta1169 is offline
post #2 of 3 Old 03-23-2008, 07:21 PM
89blkcomanche
follow the upper radiator hose and you will see it going to a housing, unbolt the 2 bolts and its under there, when you picking up a thermostat get a haynes manual, they show how to do the basic maintenance
93' ZJ 4.0l 4x4 auto, trail rig, 6 kc's, green and gray, 3.73 swap, 32x11.50 bfg mudd terrain
89' comanche, 2.5L 80k original miles, single stage paint- sold
89blkcomanche is offline
post #3 of 3 Old 03-24-2008, 10:14 PM
SB6114
1987 MJ Comanche
Yes you can follow the large top radiator hose out of the radiator, the housing should be located on the engine heads right at the front above your belt.
'01 XJ Sport, 4.0 with NV3550, 4x4, Up Country. Added: electric fan conversion, overhead console, and TUPY head (@%&$^#!).
'87 MJ shortbed, no rust! - Restoring using best parts from '87, '89, '96, '01 MJ's/XJ's. Black with chrome, Up Country, D44, NV3550, fog lights, roll bar.
SB6114 is offline
1988 Comanche 2.5L PCV valve location? NOBO2010 MJ Comanche Technical Forum 8 01-28-2010 01:09 PM
New thermostat..which one?! myth assassin XJ Cherokee Technical Forum 15 08-22-2006 02:52 PM
Thermostat location WRFD17 XJ Cherokee Technical Forum 5 12-02-2004 05:43 PM
Thermostat Location 89 XJ Vito Corleone XJ Cherokee Technical Forum 1 11-11-2003 08:53 AM
thermostat 01xjrock XJ Cherokee Technical Forum 1 04-13-2003 01:50 PM
