testing a cd player - JeepForum.com
post #1 of 2 Old 03-30-2008, 01:22 PM Thread Starter
np223
1988 MJ Comanche
testing a cd player
how can i go about testing my cd player to see if it is working? whats the easiest way
np223 is offline
post #2 of 2 Old 04-17-2008, 02:45 PM
wranglercory
testing a stereo
Get a 12 volt battery or a power supply that puts out 12 volts and a test speaker. Take both the red and yellow wires twist them together those will go to the + and take the black wire and it goes to - then it should power on and you can use white & white/black front left speaker , gray & gray/black front right , then green & green/black rear left , and violet & violet/black rear right that should get it powered up and be able to test it .
Addicted to Jeeps , had 1994 YJ, &1994 XJ, Have now 1997 XJ, 1996 XJ, &my project 1989 MJ, just bought another 89 MJ with a 4 cyl.
wranglercory is offline
ECM testing daniele70 XJ Cherokee Technical Forum 2 08-27-2009 10:22 AM
Did a little testing Fullsizexj XJ Cherokee Technical Forum 11 06-17-2007 03:04 PM
TPS testing help!! twardozrally XJ Cherokee Technical Forum 1 04-13-2005 04:45 PM
Testing the CPS PhickleP XJ Cherokee Technical Forum 1 12-06-2004 09:06 AM
TPS testing 88XJ_WI XJ Cherokee Technical Forum 1 06-21-2004 03:16 PM
