SYE question - JeepForum.com
post #1 of 11 Old 09-30-2012, 10:03 PM Thread Starter
USMC_XJ
2003 WJ
SYE question
What options do I have for the MJ. Im swapping in a 231 with an sye on it...
1994 Cherokee Sport - 4.0 HO - AW4 - 4WD
Originally Posted by Rob99
The next time you want to tell a story but not get people's opinions, rather than post it on an internet forum, open up Microsoft Word, type your story there, then click on the little X in the top right corner and then hit yourself in the head with a sledge hammer.
Originally Posted by bigsquat
If he finds the yj section im putting round headlights on mine.
USMC_XJ is offline
post #2 of 11 Old 10-01-2012, 06:28 PM
josh94xj
1994 XJ Cherokee
What exactly are u asking?
Sent from my 2 door Cherokee!
"Jeep. Go prepared."
Originally Posted by Teal2doorXJ View Post
i say screw it and just rawdog it!
Originally Posted by cherokeekid58 View Post
Selling your jeep is like selling your soul....
NEW JEEP PROJECT COMEING SOON!
josh94xj is offline
post #3 of 11 Old 10-01-2012, 08:27 PM Thread Starter
USMC_XJ
2003 WJ
Damn, some of my message didn't post. I was wondering what options I have as far as a rear drive shaft to use with an sye. Are there any junkyard shafts that I can make use of? Or am I looking at getting a custom one made?
USMC_XJ is offline
post #4 of 11 Old 10-07-2012, 11:44 AM
SnowYJ
1988 MJ Comanche
well how much lift does it have? long or shortbed?
I go to college and I drive a Jeep.
SnowYJ is offline
post #5 of 11 Old 10-07-2012, 05:12 PM Thread Starter
USMC_XJ
2003 WJ
It's going to be about 6.5". Short bed. 4.0 5 SPD 231. I have been reading about lengthening a Cherokee front drive shaft. Or just have one built at a local shop. I have access to a welder and tubing. So I was thinking of just extending the Cherokee shaft. This is strictly my offroad toy. But, I drive it around town on some days. Vehicle.speed will not be faster than 55.
USMC_XJ is offline
post #6 of 11 Old 10-14-2012, 10:43 PM
kbrawlz
for super budget. you could buy a zj front driveline (CV/double cardan) from the jyard or craigslist, then take it to a driveline shop like Six States to have it lengthened. you just give them the measurements. it'll probably cost around $90, but they'll balance it and everything.
but you can do that with most any driveline from the j-yard, just make sure it uses the same u-joints and have the shaft lengthened or shortened.
jeep or die
kbrawlz is offline
post #7 of 11 Old 10-15-2012, 07:51 PM Thread Starter
USMC_XJ
2003 WJ
Is that in NC? I have 2 spare front driveshafts from a Cherokee. Guess ill take one of them up there..
USMC_XJ is offline
post #8 of 11 Old 10-15-2012, 10:11 PM
kbrawlz
yeah sorry. i guess Six States is west coast only. But it gives you an idea of a good company to look for in your area that does drivelines and such.
Most forums i read for the hackntap sye use the zj front driveline in the rear on xjs, i dont know if its any different than the xj front driveline. but it might be the same. if its not, it might be longer, or beefier for the v8 zj models.
jeep or die
kbrawlz is offline
post #9 of 11 Old 10-15-2012, 10:39 PM Thread Starter
USMC_XJ
2003 WJ
At the moment, the drivetrain is in a 94 XJ. It has a hack and tap and un modified front driveshaft for the rear axle. But, the measured length is 31 closed, 36 fully extended. However, I've been reading the stock length drive shaft of the swb MJ is 42". So I would need one that's 40" collapsed, 46" extended, since the sye moves the Ujoint up 1 inch. I guess I could take a stock from drive shaft and have them extend it. How safe is that though?
USMC_XJ is offline
post #10 of 11 Old 10-16-2012, 01:34 AM
kbrawlz
they cut off the tube and keep the ends. then they weld on a new tube with a thicker wall. they don't weld on a small section additional length. so i guess as safe as a brand new driveshaft could be.
jeep or die
kbrawlz is offline
post #11 of 11 Old 10-16-2012, 01:40 AM Thread Starter
USMC_XJ
2003 WJ
Cool. Guess I just need to find a shop around here...
USMC_XJ is offline
