suspension noise - JeepForum.com
post #1 of 5 Old 03-31-2008, 10:25 AM Thread Starter
USN1982
1989 MJ Comanche
suspension noise
hey brothers
my mj was purchased built already
i found that when i turn the wheel a sanpping noise is made
nothing is broken and it sounds like a popping noise
i checked the u joints and everthing else
it needs new boots for the tie rod ends and im putting new sway bar bushings right now
no death wobble at all and it is lifted about 5in
and has 33's
USN1982 is offline
post #2 of 5 Old 03-31-2008, 05:50 PM
maddzz
1989 MJ Comanche
You should post at comancheclub.com
maddzz is offline
post #3 of 5 Old 03-31-2008, 07:03 PM Thread Starter
USN1982
1989 MJ Comanche
yo
thanks bro
it didnt seem to work when i created a user account but I will try again later
USN1982 is offline
post #4 of 5 Old 04-01-2008, 02:36 PM
Pete M
1988 MJ Comanche
PM me with the screen name you tried and I'll look into it.
Oh, and Check the condition of your track bar. My 88 makes a popping noise on turns because there's just a little bit of slop in it. Also check the track bar bracket for movement. I've had that on my 90 MJ.
Jeep on!
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #5 of 5 Old 04-16-2008, 07:19 AM Thread Starter
USN1982
1989 MJ Comanche
pete m that was the problem on mine as well. had to drop the skid to get to it . thank you brother.
USN1982 is offline
Noise from front of engine - not suspension kongpheng XJ Cherokee Technical Forum 3 12-17-2009 12:34 AM
Front suspension noise. (NON-lifted) 4.0H.O.XJ XJ Cherokee Technical Forum 2 01-15-2007 09:22 AM
clinking noise in the suspension rosader XJ Cherokee Technical Forum 2 07-19-2006 11:11 PM
front Suspension noise Saint18z XJ Cherokee Technical Forum 9 03-24-2006 12:56 PM
Suspension Noise Left front E.C._Cherokee93 XJ Cherokee Technical Forum 11 02-13-2005 03:47 PM
