At A Stump HELP - JeepForum.com
post #1 of 4 Old 02-03-2014, 09:51 PM Thread Starter
bozzman080
1987 MJ Comanche
my 4.0 will not run right HELP!!!
I just bought a 1987 jeep Comanche 2WD 4.0 with 5speed
I am at a loss since when I test drove it she ran like a gusty 4.0 should loads of torque, now it is acting up
it was stalling and dying and the tachometer was jumping all over the place
so I did this so far
new
cap, rotor, wires, bosch platinum plugs, CPS, IAC, Fuel filter, all vacuum lines inspected and replaced as needed, Coil ,Ignition control module,
after all this a few hundred dollar's later she idles and revs only to around 2800rpm then dies out and falls on her face
also running very rich
I cant figure this out new TPS is on order
any other suggestion's , I am about to Craig's list her and walk away
bozzman080 is offline
post #2 of 4 Old 02-04-2014, 06:48 PM
Caish
1987 XJ Cherokee
unplug the Crank Position sensor and plug it back in and get one to replace it.
I would also suggest pulling it out and cleaning it off and might even try drilling
one of the holes out to a 3/8" so you can get it a little closer for better signal.
My 87 Renix occasionally won't start, when it happens, I just unplug mine and
plug it back in and its good for 2 to 4 months.
Join us on Jeeperz Creeperz on Google+
Facebook: Arkansas Jeeps
Caish is offline
post #3 of 4 Old 02-04-2014, 07:57 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Click on the link in my signature. Do posts 1 through 5. Platinum plugs suck BTW. NGK all the way.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #4 of 4 Old 02-04-2014, 11:58 PM Thread Starter
bozzman080
1987 MJ Comanche
Shes alive , i can not believe it was the cat it was beyond plugged up so if you have done all that i did check that
hesitating , no power
