Stumbling problem - JeepForum.com
post #1 of 4 Old 02-13-2005, 08:57 PM Thread Starter
Ishodu
Stumbling problem
I am getting some stumbling out of my truck. More so when cold happens around 2k. And when I give it a good dose of gas. And let up it will also start doing this such as climbing a hill on a road. If I floor it, it seems to go away. You guys think maybe the TPS or fuel pump? I have replaced cap, rotor, plugs and wires, fuel filter and air filter. Along with a good TB cleaning. Its a 4.0l btw.
TIA.
87 Jeep Comanche MT
95 Taurus SHO MTX
Ishodu is offline
post #2 of 4 Old 02-14-2005, 05:46 AM
cj7xjmj
cj7xjmj's Avatar
It could be any number of things, but I think letting your truck warm up, might cure the problem.
Patrick
90 Comanche thing. Exo-cage, tube bed, with a few other things done Here is a link to some pics of it
If you have to ask why... Its a truggy thing and you wouldn't understand
cj7xjmj is offline
post #3 of 4 Old 02-14-2005, 07:10 AM
krodeMJ
Does it happen more easily in higher gears? And does it cause the truck to jump a little? It could also be a worn clutch.
krodeMJ is offline
post #4 of 4 Old 02-14-2005, 01:44 PM Thread Starter
Ishodu
Makes no difference in temp as to the act it does. Just more noticeable when colder. Its not a slipping clutch. It will do it in every gear and the tack will go down with the loss of power not slip and go up.
87 Jeep Comanche MT
95 Taurus SHO MTX
Ishodu is offline
4.0 stumbling badly!! wahoo50 XJ Cherokee Technical Forum 11 01-31-2009 06:16 AM
Still Stumbling! Need Help! kongpheng XJ Cherokee Technical Forum 13 11-03-2008 06:09 PM
stumbling? over bumps callingclair XJ Cherokee Technical Forum 10 09-16-2007 06:32 PM
stumbling now and then?? shierkahn XJ Cherokee Technical Forum 13 12-02-2006 12:59 PM
'87 stumbling on acceleration Saravix XJ Cherokee Technical Forum 1 10-28-2004 09:53 PM
