still wont start 86 comanche - JeepForum.com
post #1 of 3 Old 01-14-2013, 10:48 AM Thread Starter
bob1965
cranks wont start new pump no gas is being pumped out even hooked up to 12 volts the pump is not pumping its the correct bosch pump pump will run just not pumping also how do you know if the neutral safety switch is bad it will crank in park but not neutral any ides thanks
bob1965 is offline
post #2 of 3 Old 01-15-2013, 12:01 PM
hillbilly51
1988 MJ Comanche
Can you hear the pump run when voltage is applied?
Are you sure that there is fuel in the tank?
Where are you checking for fuel flow when the pump is running?
Are you sure that the new pump was correctly installed?
steve
hillbilly51 is offline
post #3 of 3 Old 01-15-2013, 07:55 PM
mj40
1989 MJ Comanche
what engine/transmission
no start in neutral- may just be adjustment.. wiggle shifter in neutral and see if it'll crank..
as for pump..as above poster said also check to be sure its hooked up to the right line and not the vent or return line..
mj40 is offline
