Still Running Hot..... - JeepForum.com
post #1 of 7 Old 08-30-2013, 12:33 PM Thread Starter
TrucksBootsNGun
1988 MJ Comanche
Ok so I am still running hot in my '88 MJ 4.0L even after I swapped the radiator for the '92 open design (also swapped heater control valve and made an overflow tank). While I was in there I decided to swap out the thermometer for a new 160* one instead of the stock 195*. I also replaced the water pump and I am still running the pure distilled water from when we tested it for leaks. At highway speeds the thermometer says exactly on 160* but when you are wheeling at lower speeds she runs at about 210* never got it much higher because it was a short trail but i feel like its gonna keep going up. I am slightly worried because living in Flagstaff we need antifreeze which means less water. Did I miss anything when I swapped everything over?
TrucksBootsNGun is offline
post #2 of 7 Old 08-31-2013, 08:56 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
210 is normal. A 195* THERMOSTAT should work fine. 160* is too low. You'll be freezing your *** off in the mornings this winter in Flagstaff. The fan clutch is most likely needing replaced.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 7 Old 09-03-2013, 07:24 PM Thread Starter
TrucksBootsNGun
1988 MJ Comanche
The reason this I went with the 160* is I am from SD just going to college in Flagstaff. That 195* was useless in San Diego stop and go traffic. When you say clutch fan you are not referring to the electric fan that kicks on when the A/C does are you? That fan won't kick on because the A/C compressor is bad (I think its the compressor because when the system was charged and the A/C was on there was freon coming through the vents according to a sniffer do-hicky my dad has. there is a big enough leak that it was completely unpressurized in less than 5 mins) The A/C has this weird fail-safe that if the system is out of freon it wont engage the A/C clutch.
post #4 of 7 Old 09-03-2013, 08:14 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
You'll freeze your balls off in flag with a 160 stat this winter.
https://www.google.com/search?q=fan+...w=1680&bih=806
post #5 of 7 Old 09-08-2013, 06:48 PM
wgirvine
1992 XJ Cherokee
Three things:
The thermostat regulates the MINIMUM operating temp of the engine. It does not regulate the MAXIMUM temp. When a 160 degree t-stat is open, it flows the same amount of coolant as a 195 degree t-stat when it's open. The max temp of the engine is controlled by the size and efficiency of the radiator. Forcing an engine to run cooler than it was designed to will cause poor gas mileage. And other problems...
The mechanical fan has a viscous coupling, commonly called a fan clutch. It allows the fan to slip a lot (run slowly) when the air coming thru the radiator is cool. It engages and speeds up the fan when the air coming thru the radiator is hot. Overheating at low speeds (low air flow conditions) such as stop-and-go traffic is usually caused by a bad fan clutch. Replace. They don't last forever, anyway. Make sure you get the one with the funny little flat coil spring in the front.
And the electric fan comes when (1) the AC is turned on, OR (2) when the coolant gets hot... around 215, I think. You need to get that fan fixed also.
The road goes on forever, the party never ends....
wgirvine is offline
post #6 of 7 Old 09-08-2013, 07:31 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Originally Posted by wgirvine View Post
Three things:
208* or 218*.
post #7 of 7 Old 09-13-2013, 04:12 PM
carnuck
1984 J-Series Truck
195 or 180 stat, 50% antifreeze, check the waterpump blades (mine were chewed up by the spring from the bottom hose!), loosen the temp sender to burp the head "air bubble" and add a bottle of Water Wetter from Redline (or similar like Purple Ice or Amsoil cooling booster)
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
