still haveing brake an clutch problems - JeepForum.com
post #1 of 1 Old 06-24-2008, 12:35 PM Thread Starter
nate81
ok i have bled the brake system an the brake pressure has improve som but still no where near enough,still way too soft exspecialy when turning on the truck,what can i do next ?and the same with the clutch i have bled the clutch and it has improved dramaticly but now im haveing trouble getting it into gear ,it has ok pedal even with the truck running but wont move through the gears while its running,yet it moves through the gears fine when the truck isnt running.i was woundering if i have bled the system wrong what is the proper way to bleed the clutch slave cylender ?any imput would be greatly appreciated .
nate81 is offline
haveing unknown problems with my 89 cherokee 4.0 PLease help tuggey XJ Cherokee Technical Forum 18 09-23-2009 03:51 PM
anyone haveing problems with skyjacker's trackbar locater severous01 XJ Cherokee Technical Forum 8 01-22-2008 10:27 AM
Brake Problems on 87-Brake Booster? tyytyy22 XJ Cherokee Technical Forum 2 01-30-2006 11:36 AM
Brake/Clutch smell off highway Bad clutch pack? beaver24 XJ Cherokee Technical Forum 2 04-01-2005 05:39 AM
Need HELP ASAP..Lifting and haveing issues. MadDogXJ XJ Cherokee Technical Forum 16 04-22-2004 04:55 PM
