Stick shift ? - JeepForum.com
post #1 of 6 Old 03-22-2008, 05:29 PM Thread Starter
Camo Cj
1981 CJ5
Stick shift ?
I have a 91 comanchee that I put a stick shift in an now it wont start what the problem.....Any help would be greatly appreciated
Camo Cj is offline
post #2 of 6 Old 03-22-2008, 07:49 PM
Pete M
1988 MJ Comanche
Need more details please. What year is the transmission? Did you reuse the CPS that the auto trans had?
Jeep on!
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #3 of 6 Old 03-22-2008, 08:21 PM Thread Starter
Camo Cj
1981 CJ5
Sorry for not many details...Try this tranny from same year cherroke the cpu is the one from the auto....I can get it to turn over if jump at starter but hit the key an notheing, tried bypasseing the neut. switch but notheing...hope this info helps alitle better
Camo Cj is offline
post #4 of 6 Old 03-22-2008, 09:06 PM
89blkcomanche
it has to be problems with the neutral safety switch, or the cpu wont work with that year
93' ZJ 4.0l 4x4 auto, trail rig, 6 kc's, green and gray, 3.73 swap, 32x11.50 bfg mudd terrain
89' comanche, 2.5L 80k original miles, single stage paint- sold
89blkcomanche is offline
post #5 of 6 Old 03-27-2008, 09:44 AM
75SV1
I think there are wiring isses between the auto and manual wiring harnesses. I'd probably ask on the Cherokee board. I know a few people have done this swap. Also, I think you need the computer from the 5 spd vehicle.
Tom
75SV1 is offline
post #6 of 6 Old 03-28-2008, 06:16 PM
Snowplow
Snowplow's Avatar
the neut switch should have 3 wires on it 2 of them have to be grounded and it should work then i did the swapp the other wire is the backup light if i remember correctly
Snowplow is offline
new to stick shift wheeling..help cherokeeman90 XJ Cherokee Technical Forum 5 03-23-2008 11:49 PM
94 stick shift dezmoduo XJ Cherokee Technical Forum 4 10-30-2006 03:19 PM
What kind of fluid do I use in my stick shift??? Elohim1 XJ Cherokee Technical Forum 2 06-03-2005 09:45 AM
My stick shift is ugly biguglymudrs XJ Cherokee Technical Forum 9 02-06-2003 11:34 PM
