Steering wheel play - JeepForum.com
post #1 of 4 Old 01-25-2014, 08:38 PM Thread Starter
HadawayBoy89
1989 MJ Comanche
Steering wheel play
I have a 1989 jeep Comanche pioneer and there is like 3-4 inches of play in the steering. where should i look first and or how do i go about on fixing this?
HadawayBoy89 is offline
post #2 of 4 Old 01-26-2014, 05:33 PM
mopar_monkey
I just had the same issue with my 92 mj. Mine ended up being a worn steering box. What you need to do is crawl under it while someone moves the steering wheel back and forth so uou can pinpoint where all the movement is (what is worn and sloppy).
mopar_monkey is offline
post #3 of 4 Old 01-26-2014, 10:17 PM
juicy
1986 MJ Comanche
Youll get used to it lol kinda nice the more ya drive it
juicy is offline
post #4 of 4 Old 01-27-2014, 06:40 AM
Caish
1987 XJ Cherokee
The box has an adjustment screw on it, you can use it to remove the slack from the worm screw/drive gear in the box.
Assuming you do not have other issues like bad tie rod ends etc.
3-4' seems to much to be just a box though.
Join us on Jeeperz Creeperz on Google+
Facebook: Arkansas Jeeps
Caish is offline
