Steering Column Assembly - JeepForum.com
post #1 of 3 Old 10-02-2012, 12:55 PM Thread Starter
stinealbert
1989 MJ Comanche
I have an 89 comanche and am in need of detailed instructions on how to reassemble and installation of the steering column. I am fixing to have to tow it to storage so I can repair this problem.
stinealbert is offline
post #2 of 3 Old 10-03-2012, 07:40 PM
ftpiercecracker
1990 MJ Comanche
Do you mean the mechanical portion? Or are you talking about the whole wiring harness that runs up the column's length?
ftpiercecracker is offline
post #3 of 3 Old 10-05-2012, 05:23 PM
mj40
1989 MJ Comanche
something like this, if you have tilt, its a gm column, so parts from some late 80's early 90's will swap over too..
mj40 is offline
My steering column is a POS cheepjeep96 XJ Cherokee Technical Forum 3 03-01-2011 09:09 AM
steering column help 87xjjeep XJ Cherokee Technical Forum 6 12-16-2008 11:11 PM
need to take steering column apart tozier9 XJ Cherokee Technical Forum 9 05-23-2007 12:22 PM
steering gear assembly Exhale XJ Cherokee Technical Forum 1 09-17-2006 10:19 AM
