spare tire info - JeepForum.com
post #1 of 2 Old 05-12-2008, 08:26 PM Thread Starter
thejum57
spare tire info
Does anyone have any pics, or info about the spare tire setup for a Comanche, 86 if it matters. Also, can you just replace the big "wingnut" on the wire that lowers the spare, or do you need to replace the entire setup??
thejum57 is offline
post #2 of 2 Old 05-27-2008, 05:46 AM
Abstruse
Have an 86 Comanche, the spare tire pulls up on a cable just behind the rear bumper like many vehicles do. Not sure what your actual question or problem is though to answer you?
If your "big wingnut" part has broken off but the rest of it still cranks up and down you wouldn't actually have to replace the entire thing to just get it working again. All you would need is a long enough metal dowel or bolt to hold the tire and wrap the cable around this bolt fixed with a "U" bolt or "Cable Clamp". Probably cost you an entire dollar for all of it at Home Depot.
Abstruse is offline
sub in spare tire orangez XJ Cherokee Technical Forum 5 04-10-2007 04:50 PM
Will a 30x9.50 tire fit in the stock spare tire location? 79bigmack XJ Cherokee Technical Forum 4 02-03-2007 01:16 PM
Help with spare tire Julius4x4 XJ Cherokee Technical Forum 6 07-12-2006 01:24 PM
spare tire bigjohnson69 XJ Cherokee Technical Forum 11 03-10-2006 01:02 PM
Spare tire LOCKED UP XJ Cherokee Technical Forum 7 06-20-2002 01:18 AM
