is something missing? - Page 2 - JeepForum.com
post #16 of 26 Old 12-10-2012, 06:33 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
How high? And your oil pressure sending unit can be bad.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #17 of 26 Old 12-10-2012, 07:17 AM
97_4popper
If it is pegging the gauge, then it is probably faulty. Doubt if your oil pressure is that high.The sending unit may be incorrect.
If you or the previous owner replaced the gauges from the set that had idiot lights, then you simply have the wrong sending unit.
Replace the sending unit first. It is located by the distributor cap.
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
Check out comancheclub.com...
My build thread:
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline
post #18 of 26 Old 12-10-2012, 09:48 AM Thread Starter
Rican142
I think I did replace it. Cause when I was reviving the truck I seen that it was broken all it is, is like a little screw on knob that has a single wire running to it right?
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #19 of 26 Old 12-10-2012, 09:48 AM Thread Starter
Rican142
Btw, what r u talking about, idiot lights?
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #20 of 26 Old 12-10-2012, 10:04 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
It's a real stretch, but if someone had switched your dash from the one with warning lights instead of gauges the sender could be wrong. The light are called idiot lights as a slang term.
post #21 of 26 Old 12-10-2012, 10:16 AM Thread Starter
Rican142
Ahhhh, I understand. No I Thom there the original ones
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #22 of 26 Old 12-10-2012, 02:36 PM Thread Starter
Rican142
And what is happening when ur cluthh is slipping?
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #23 of 26 Old 12-10-2012, 03:57 PM
97_4popper
Like I told you in another thread, take off and when you are to shift in 2nd, put it in 4th instead. Then gun it. If the engine revs and speed doesn't go up or barely goes up, then your clutch is slipping.
My build thread:
post #24 of 26 Old 12-10-2012, 04:22 PM Thread Starter
Rican142
Nooo, not how do I fig it out. What is happening when a church is slipping
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #25 of 26 Old 12-10-2012, 05:41 PM
97_4popper
The clutch engages the transmission.
If it is slipping, then the power of the engine is not being applied to the transmission and therefore the wheels.
RPM's will go up, but speed will not.
My build thread:
post #26 of 26 Old 12-10-2012, 06:20 PM Thread Starter
Rican142
Ohhhhh. But why would this have happend so suddenly?
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
