is something missing? - JeepForum.com
post #1 of 26 Old 12-05-2012, 06:41 PM Thread Starter
Rican142
Is there supposes to be somethint between the plate in front of the bellhouseing and the bellhousing itself? When I get done driving it smells of gear oil and there's oil dripping from the bottom of the truck. Just wondering if that's normal
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #2 of 26 Old 12-06-2012, 08:58 AM
97_4popper
1990 MJ Comanche
Nope.
You sure it's gear oil and not motor oil?
Could be motor oil from the rear main. That is common with these. I replaced most of the gaskets on mine last year. Rear main included.
No more leaky.
Good Luck.
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
Check out comancheclub.com...
My build thread:
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline
post #3 of 26 Old 12-07-2012, 05:02 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Correct. No seal there. But read this first before tackling the rear main:
I'd be looking up ABOVE first, and VERIFYING the source of the oil leak YOURSELF.
Everybody, who doesn't own or have to pay for or perform your vehicle repairs, loves to poke their noggin UNDER the Jeep and come out bearing the false bad news that your RMS is leaking.
Many mechanics, friends, and good old Uncle Bob seem to enjoy telling you it’s the rear main seal. Has a catastrophic ring to it, doesn’t it?
A simple leak at the back of the valve cover or other source could produce the same symptoms. You don’t need to be a mechanic to figure this out. If you have good eyesight and a dim flashlight, you’re good to go on your own. Don't jump on the RMS/oil pan gasket bandwagon right off the bat.
Almost any oil leak on your 4.0 is gonna drip from the RMS area for two simple reasons.
First off, the engine sits nose-up and any oil will run back to the RMS area. Secondly, the RMS area is also the lowest point on the engine. Simple physics and the old plumber's adage apply here. "***** flows downhill".
Valve cover gasket, oil pressure sending unit, oil filter adapter seals and distributor gasket, in that order, have to be eliminated as possibilities first.
Revised 9-15-2012
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is online now
post #4 of 26 Old 12-07-2012, 07:10 AM
97_4popper
1990 MJ Comanche
I actually replaced all of the above while I had the old mule apart.
My build thread:
post #5 of 26 Old 12-08-2012, 09:05 PM Thread Starter
Rican142
Well it sure as heck smells like gear oil. Could it be a leak from the tranny? My dad also said it was the rms
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #6 of 26 Old 12-08-2012, 10:05 PM Thread Starter
Rican142
And also, i checked my oil and i was completley out
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #7 of 26 Old 12-09-2012, 05:04 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
6 quarts of oil leaking has to make a heck of a mess.
post #8 of 26 Old 12-09-2012, 07:33 AM Thread Starter
Rican142
Yes it would, but it was a slow leak.
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #9 of 26 Old 12-09-2012, 07:41 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Then my queston is:
If it was a SLOW leak, how come you ran out of oil? Never check it?
post #10 of 26 Old 12-09-2012, 04:51 PM Thread Starter
Rican142
No its been a few months that ice had it on the road, and my oil gauge must be broken or some thing cause its aaaaaall the way to the right
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #11 of 26 Old 12-09-2012, 05:44 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
You're not getting of that easy. Checking your oil using the dipstick has nothing to do with what your oil pressure gauge is reading or road conditions. Oil gauge is only indicative of pressure, not level.
post #12 of 26 Old 12-09-2012, 07:02 PM Thread Starter
Rican142
:O.. R U SERIOUS?! I thought that it was showing the oil level!
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #13 of 26 Old 12-09-2012, 07:03 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I'm serious as a heart attack. You ?
post #14 of 26 Old 12-09-2012, 10:14 PM Thread Starter
Rican142
Wow..so what does it mean if my oil pressure is that high?
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #15 of 26 Old 12-09-2012, 10:14 PM Thread Starter
Rican142
And What kind of damage can it do
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
