Signals and Hazards wont work!! HELP!! - JeepForum.com
post #1 of 10 Old 03-07-2013, 09:13 AM Thread Starter
Jeep_Creeper
1987 MJ Comanche
Hello all, i bought my 1st comanche yesterday and all of the signals DID work except for the front left.. it would stay on continuously no matter what, aslong as the headlights were on, and the hazard lights wouldnt do anything... now today NONE of the signals work, and the front left still stays completely illuminated aslong as the headlights are on, and the hazards also still don't work, now i have noticed the interior arrow lights no longer light up and no longer makes the clicking noise when you turn.
Ive ripped right into the dash, checked all of the relays, fuses appear to be good, etc
if anyone can give me some helpful advice on how to get my signals working it would be greatly appreciated
Thanks fellow Jeep owners!!
Jeep_Creeper is offline
post #2 of 10 Old 03-14-2013, 10:55 PM
ftpiercecracker
1990 MJ Comanche
Pull and visually inspect ALL fuses, dont just assume. If they look questionable chuck em and put a new one in, make sure its the right amps as well. Also check all grounds, if yours is all original there will be only one ground for the interior. Sitting in the driver seat it should be directly above your left knee, you will probably have to remove the knee board to get to it. Make sure it is SUPER clean and tight.
Electrical is one of the hardest things to help with over the inter webs, because who knows what the previous owner might have rigged up. If its 100% untouched it makes things a little bit easier, but still difficult. My best advice would be to learn the basics of using a multimeter and test light, these two tools will become you best friends VERY quickly.
ftpiercecracker is offline
post #3 of 10 Old 03-17-2013, 06:42 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I suggest unplugging EVERY electrical connection in the engine bay you can find, whether engine related or not, and spraying it out with a good electronics cleaner, visually inspecting the terminals making sure they haven’t retracted into the plastic holder, and then plugging it back together. There’s a critical 10-pin connector for the front lighting system located in front of the air cleaner and behind the left headlight assembly. Don’t miss that one. Also be sure that the connectors to the ballast resistor mounted near the air cleaner housing are clean and tight.
ALL of the relays should be removed, the terminals wire-brushed until shiny, and the receptacles sprayed out with contact cleaner. Then plug them back in. I do this on every Renix Jeep I purchase or work on for someone else.
Revised 07/23/2012
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #4 of 10 Old 03-18-2013, 05:43 AM
Shortbed
1989 MJ Comanche
The left blinker is supposed to remain on, it indicates that your head lights are on.
Shortbed is offline
post #5 of 10 Old 03-18-2013, 06:00 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Huh? Uh, no.
post #6 of 10 Old 03-18-2013, 06:57 PM
ftpiercecracker
1990 MJ Comanche
i hope hes being sarcastic or just miss typed something.
post #7 of 10 Old 03-18-2013, 08:27 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Shotgunner.
post #8 of 10 Old 03-19-2013, 10:59 PM
ftpiercecracker
1990 MJ Comanche
Originally Posted by cruiser54 View Post
Shotgunner.
I am not up to date with all the lingo, what does "shotgunner" mean?
post #9 of 10 Old 03-22-2013, 05:40 AM
Shortbed
1989 MJ Comanche
Nope didnt mistype, and im not sarcastic, the light is supposed to be on.
Shortbed is offline
post #10 of 10 Old 03-22-2013, 05:48 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Uh, no. Only if there's a backfeed, poor ground, or some other wiring issue.
connection , electrical , short , troubleshoot , wiring
