Signal lights issue - JeepForum.com
post #1 of 10 Old 05-28-2013, 12:20 PM Thread Starter
stuiecomanche91
Signal lights issue
So my 87 Comanches signal light stop working I change the flasher it's not that so I'm figuring its a ground or the signal arm itself any ideas??
stuiecomanche91 is offline
post #2 of 10 Old 05-28-2013, 05:31 PM
mj40
1989 MJ Comanche
my 89 was the front socket on one and connector plug on the other side..
check the sockets and connections behind the lens first..
mj40 is offline
post #3 of 10 Old 05-30-2013, 08:00 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
There's 2 flashers. Sure you swapped the correct one? One is for turns, the othe other hazards.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #4 of 10 Old 05-30-2013, 11:06 AM Thread Starter
stuiecomanche91
I'm not stupid I already said I changed the flasher so it's not the flasher it's the arm or a bad ground please read before you reply
post #5 of 10 Old 05-30-2013, 05:17 PM
mj40
1989 MJ Comanche
we asked/answered....he never said .........wow........good luck...
we'll sit back now and watch....k....
mj40 is offline
post #6 of 10 Old 05-30-2013, 05:27 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Listen, piss-ant. There are 2 identical looking flashers in that fusebox!! Very common for people to mistakenly check the wrong one or be unaware there are 2 flashers in the box. Your attitude stinks. You're on your own know-it-all.
post #7 of 10 Old 05-30-2013, 06:22 PM Thread Starter
stuiecomanche91
I checked both I didn't give you additude btw, it's just frustrating getting told something that I've tried several times so just calm the frick down buddy
post #8 of 10 Old 05-30-2013, 08:48 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Yeah. A whole 1 time you were told that, so you start giving us crap.
I'm calm as I can be. MY turn signals work in all 3 of my Jeeps. No hand signals or temper tantrums from me.
MJ40: How are your turn signals working?
post #9 of 10 Old 05-30-2013, 09:25 PM
mj40
1989 MJ Comanche
used as a snowplow for winter and bush ride through the summer.... i'm the guy signaling in the bush....
mj40 is offline
post #10 of 10 Old 05-30-2013, 09:44 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Glad to hear it. Panties aren't in a bunch and no need for Midol? Life is good.
