shut down - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Comanche Technical Forum > shut down
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 11-17-2006, 05:58 AM   #1
scrapy
shut down
I have a 88 comanchee. It is shuting down after about 30min of idel time or drive time. I have changed cps, tps ,fuel pump,coil,ignition modul,checked ground cabel, and the yellow box under dash .Im thinking of changing out the distrbuter next. Well changed distrbuter no change still shuts down after 30 min . I have noticed it runs longer the colder it is (out side temp) Does anyone know were the automatic shutdown relay switch is located ????????? The haynes manual has it listed for my i6 4.0L .
scrapy is offline   Reply With Quote
Unread 11-17-2006, 07:54 AM   #2
Country Jeep
Comanche Kemosabe
Country Jeep's Avatar
Sounds like you're screwed. But I guess it COULD still be the distributor, but from the sounds of it, you either have a major computer issue somewhere down the line of the idle air motor, or just the computer itself.
Very odd indeed, but I guess it could be the idle air motor.
Main rig under screen-name...
'96 XJ Country (pearl white) 2WD, 4.0L HO I6, AW4. Daily driver.
'98 XJ Classic (moss green) 2WD, 4.0L HO I6, AW4. Restoration project.
Gone, but not forgotten: '88 MJ Pioneer, '94 ZJ Limited, '85 CJ7, '98 ZJ Limited
Blue Jeep Club Member #113
How to install an RB1 w/ working nav into a '97-'01 XJ!
Country Jeep is offline   Reply With Quote
Unread 11-17-2006, 02:27 PM   #3
eclipse27
ick...yea soudns like ur computer is messed up
eclipse27 is offline   Reply With Quote
