Searching- New Valve Cover - JeepForum.com
post #1 of 5 Old 03-05-2012, 11:41 AM Thread Starter
JCR0SS
1986 MJ Comanche
I Have a Jeep 2.5L 4cyl Comanche Custom. I am looking for a replacement valve cover, not plastic! Any suggestions on where to look? I am in Phoenix, AZ. The Crown brand plastic valve cover does not fit my truck. My current plastic valve cover is cracked to all hell and leaking oil.
JCR0SS is offline
post #2 of 5 Old 03-08-2012, 11:26 AM
gus7
i heard your pain
i got aluminum valve cover from the junkyard too other jeeps had them too like XJ etc
gus7 is offline
post #3 of 5 Old 03-08-2012, 09:18 PM
greaseslapper
1987 MJ Comanche
JC whitney, thats where i got mine, and there like $90. here is some info, that valve cover does have torque specs it's like 18 inch pounds or something like that. they dont make metal valve covers for the 2.5L amc motor.
2.5 four wheel drive.
greaseslapper is offline
post #4 of 5 Old 03-18-2012, 12:32 AM Thread Starter
JCR0SS
1986 MJ Comanche
Thanks for the info I got the valve cover. Does your comanche have CCV system instead of the PCV system for valve cover ventilation? I am having trouble with oil leaking from the top of the dip stick and around the oil cap.
JCR0SS is offline
post #5 of 5 Old 03-19-2012, 08:10 PM
gus7
simple fix
with the aluminum valve cover ,you can use pcv valve from 1987 mighty max 2.4 liter -this set up works very well
gus7 is offline
PCV/other valve on valve cover leaking CJ7RX7 XJ Cherokee Technical Forum 10 04-12-2010 01:18 AM
Valve cover gasket! Cover me I'm going in! polizi212 XJ/MJ Cherokee Non-Technical Forum 15 03-22-2010 04:35 PM
What is this on the valve cover? tock172 XJ Cherokee Technical Forum 19 03-02-2009 11:03 PM
How do I remove ccv valve from valve cover ExJ XJ Cherokee Technical Forum 5 01-21-2009 09:40 PM
What to look for when Valve cover off?!? Meatroach XJ Cherokee Technical Forum 10 07-10-2006 02:14 AM
