replacing ccv system hose fitting - JeepForum.com
post #1 of 13 Old 06-25-2005, 06:27 PM Thread Starter
paulda
went to the dealership today and bought 3 hoses for a total of $103.00
well one piece I purchased was the Crankcase Ventiliation system hose and fitting. I'm trying to replace the fitting and cannot get the fitting in, because it is much bigger in proportion to the hole. any ideas?
1990 jeep comanche sport truck
paulda is offline
post #2 of 13 Old 06-25-2005, 07:43 PM
DirtyCommanche
That's a little devil, I had to ask my friendly neighbourhood mechanic how when I did mine. He said to take a flat head screwdriver and use it to push the flang in and work your way around. Very easy once you do it that way.
DirtyCommanche is offline
post #3 of 13 Old 06-25-2005, 09:22 PM
Ed in North Ga
1989 MJ Comanche
heres a pic: http://home.comcast.net/~strzelec.pl/MVC-007F.JPG
http://home.comcast.net/~strzelec.pl/MVC-008F.JPG
pssssstttt...i`ll tell you a few secrets, but you cant tell anyone else.
#1- the CCV harness, in all its glory, is available through NAPA at a greatly reduced price-if you know where to look-its in their master catalogue, not online, not in the computers-but in the paperback catalogue.
#2-the friendly people at the jeep dealership parts department have a way of selling you something, that actually, you could have gotten for free-had you known a very little juicy tidbit. The dealership parts departments love to do this- they`ll gladly sell you a part thats under recall, then claim you should have told THEM it was a recall part...when it should be the other way around. Basicly, you have to tell them its a part under recall before the process can begin.
TSB-emmision recall-#562. CCV harness and 02 sensor.
unless your on your second one, jeep has one for you for free- AND, they`ll install it free as well. Remember, thats only if you havent replaced it once already- call jeep dealership, have them run the VIN and find out IF someone before you has had the recall done already-if not, FREE PARTS!
1989 Jeep MJ- 200,000- 28mpg. If its a Renix, its all good. 1989 XJ (sold) 310,000- 29mpg. Renix. See the pattern?
Ed in North Ga is offline
post #4 of 13 Old 06-26-2005, 03:52 PM Thread Starter
paulda
You are right, neighbors are a good thing, I had him come over and after some grease and sweat he was able to get the fitting in.
Ed, thanks for the info
Question, there is suppose to be air flowing in the CCV hose from the air cleaner to the rocker arm cover? I checked and there seems to be no air flow
paulda is offline
post #5 of 13 Old 06-26-2005, 05:34 PM
Ed in North Ga
1989 MJ Comanche
Ed, do you have more information about this recall?
no-its just your standard recall- I "paid" for mine before I found out that I should have gotten it for free...so, I got one free one comeing to me when this one fails. The "catch" is, if you do recall work, they have to install-they cant just give it to you-least that was the way it was explained to me....left that out, sorry.
I didnt see any difference between the two-- they "say" that the inside diameter is larger on the new one...if it is, its not that much bigger to my eye. The biggie problem with them is at the valve cover side- it plugs up with carbon...easy fix is weedeater string (0.90) and a bit of wd-40--- spray it in, ream it out. If its clogged, you get driveability problems, and a weird idle thats not stable...it wobbles.
air from the air cleaner to the rocker?...no- from the rocker to the air cleaner, yes- thats the way the vacuume go`s, when the bimetal sensor in the air cleaner is open-closed theres nothing. The same sensor "kinda" regulates the backside of the EGR solinoid-thats the other vac line on the airbox-....theres a gremlin that lives in there, so sometimes it works, sometimes it wont....beware the gremlin.
post #6 of 13 Old 06-26-2005, 06:02 PM Thread Starter
paulda
The reason I thought that air came from the air cleaner is what my manual says:
"A fresh air supply hose from the air cleaner is connected to the top rear of the cover. When the engine is operating, fresh air enters the engine and mixes with the crankcases vapors. Manifold vacuum draws the vapor/air mixture through the metered orifice and into the intake manifold."
When I replaced the first hose, which was the thin one to the intake manifold fitting, it ran and idled much smoother than before. Then when I replaced the cracked/borken CCV hoses connected to the air cleaner it runs more rough. It was nice to have it finally running smooth and when I replaced that second part it doesn't anymore, and that dang muffler rattles again.
paulda is offline
post #7 of 13 Old 06-26-2005, 06:18 PM Thread Starter
paulda
well i just took it out again and i guess it wasn't running that bad...i just thought it ran smoother before i put that other hose in...and the rattling is stillt here
paulda is offline
post #8 of 13 Old 06-27-2005, 06:46 AM
cj7xjmj
cj7xjmj's Avatar
Just FYI, if you rmove the back CCV hose on your valve cover, and replace it with a PCV grommet and PCV valve from a 85 cj7, you can run 3/8 fuel line to where it connects to the intake, and replace that with, a 3/8 air chuck. Problem solved. Costs under 20 bucks, and works like a champ.
Patrick
90 Comanche thing. Exo-cage, tube bed, with a few other things done Here is a link to some pics of it
If you have to ask why... Its a truggy thing and you wouldn't understand
cj7xjmj is offline
post #9 of 13 Old 01-27-2009, 06:52 AM
zacharyt
Fresh Air Inlet Hose 4.0
Ed,
I must admit that I am confused also about the airflow. The hose that goes to the front of the rocker arm cover is identified as a fresh air inlet hose from things I have read in the Haynes manual also. I know this post is several years old, but I am reading all of these older posts in an effort to keep oil out of my air cleaner as well. Trying to keep my 88 going for a couple more years.
Also, weedeater line run through the small ccv hosing to get it unclogged = GOLDEN!
zacharyt is offline
post #10 of 13 Old 02-06-2009, 06:32 PM
Skimboarder
1992 XJ Cherokee
Ooops nvm...
Skimboarder is offline
post #11 of 13 Old 01-23-2010, 07:44 AM
talentjeep
1987 XJ Cherokee
Patrick
I know this is an old thread. Has anyone done this? Does it work?
'87 XJ Pioneer with 32" KM2s, etc.
talentjeep is offline
post #12 of 13 Old 01-23-2010, 10:29 AM
Sukebe
1988 XJ Cherokee
Here is one guys solution. I think I am going to try it. I am still searching for others who have utilized this fix successfully.
Funny thing is, NAPA part number for 85 CJ7 PCV is the same as the part they list for my 88 XJ Limited... guess I'll have to go down and actually take a look at the part.
Sukebe is offline
post #13 of 13 Old 10-11-2010, 03:07 PM
blk88
blk88's Avatar
1988 XJ Cherokee
Here's how I fixed it on my '88 XJ a year and a half ago and no problems.
Blow-By
Envalve
En-Valve, The SMART PCV Valve.
blk88 is offline
Which fitting is the low pressure on a 99 XJ AC system? lowcar100 XJ Cherokee Technical Forum 4 06-18-2009 05:46 PM
How do you separate the transmission cooler copper fitting from the rubber hose? Indian-man XJ Cherokee Technical Forum 5 09-03-2008 11:26 PM
Need helpful info on replacing power steering pump and hose??Anyone done it? mtn121 XJ Cherokee Technical Forum 5 04-16-2008 12:08 PM
Replacing lower radiator hose inogenius XJ Cherokee Technical Forum 4 12-01-2006 05:13 PM
Replacing P/S hose ddoffroad XJ Cherokee Technical Forum 4 10-30-2004 08:27 PM
