Quantcast Project CRD MJ is born: - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Comanche Technical Forum > Project CRD MJ is born:
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 03-25-2009, 11:08 PM   #46
wagster11
very nice build... wish i had the skills for this... diesel jeeps are sweet... J8
wagster11 is offline   Reply With Quote
Old 03-26-2009, 12:20 AM   #47
rmtomasin
this is a really sweet build keep it coming
-Ryan-
Built Not Bought #233
98 ZJ I6
Build Thread
rmtomasin is offline   Reply With Quote
Old 03-26-2009, 11:42 AM   #48
zluster
Originally Posted by Pete M View Post
D'oh! that's right. I must have been thinking of the one that ended up being your dad's.
The rolled one we fixed up for him was an 05, other rolled one for parts is an 05 as well.
Originally Posted by twomanyjeeps View Post
Suppose this is the best way? I keep hearing about groupbuy.
There were two groubuys on Naxja, but those are over, done with, if you want a groupbuy now you better organize your own.
zluster is offline   Reply With Quote
Old 03-26-2009, 12:16 PM   #49
twomanyjeeps
Yeah I started talking to a few of the guys on that forum, major props for what they had to go thru to get it. I might try to organize one of my own hopefully learning from a few pitfalls they encountered and try to create a much smoother transaction if at all possible. Keep up the good work on the build.
twomanyjeeps is offline   Reply With Quote
Old 03-26-2009, 12:50 PM   #50
BlueTJ28
Now someone needs to do this in a TJ or YJ and make a build thread like this one.
BlueTJ28 is offline   Reply With Quote
Old 03-26-2009, 02:17 PM   #51
zluster
I'm entertaining the thought of using my other CRD engine and swapping it into a TJ, mostly just because I think I could make $10k off the swap by reselling it.
Old 03-26-2009, 05:01 PM   #52
LalanP111
mtn dew junkie
LalanP111's Avatar
wow, very nice build!!!
1998 TJ, 4.0L, RC 2.5", 31x10.5-15 Duratracs (sold)
1988 MJ, 4.0L ..soon for be on 33's and 6.5" LA/SOA (project)
2004 TJ, 4.0L, Columbia Edition, 2"BB, 31x10.5-15 (DD, future project)
Originally Posted by Knuckelhead View Post
It takes care of me and in return, I take care of it. Takes me away from everything I don't want to be around, and back again when needed...
LalanP111 is offline   Reply With Quote
Old 03-28-2009, 05:54 PM   #53
Chosen
1987 XJ Cherokee
Oh my godddddddddd
Chosen is offline   Reply With Quote
Old 03-28-2009, 11:57 PM   #54
zluster
Not much else to add, got my passenger side mount finished today, need to modify the drivers side mount in the same way. I tried to start on that tonight but my chop saw blade self destructed, time for a new one, gotta wait till harbor freight opens tomorrow morning to get another.
After this I need to make a little plate to bolt the transmission to the transmission mount, after that I will work on clearancing the floor to clear the transfer case(trans and transfer case are a good deal further back than they were stock.
Old 03-29-2009, 07:26 PM   #55
sic2000xj
you should put of some more shots of the body if you have done anymore work on it since the last body pics you threw up.
sic2000xj is offline   Reply With Quote
Old 03-29-2009, 09:00 PM   #56
zluster
I was going to go ahead and work on fitting the fenders/header/headlights today. I have a pretty good idea of what I need to trim, and it shouldn't be too much trouble, but I needed to stop to work on homework.
Old 03-29-2009, 10:13 PM   #57
zluster
Old part of engine mount bracket cut off, new piece of angle iron tacked on.
Tacked all the way around:
I may not be the best welder, but, well........I may not be the best welder.
Look ma, no hands!
Drivers side mount under compression:
So theres that, got the engine mounts done and the engine in place, I need to modify the transmount to bolt now, and then I will need to clearance the rear floor to get the transfer case in place.
Plenty of stuff to be done.
Old 03-29-2009, 11:25 PM   #58
spyder6
Just violated my Parole
spyder6's Avatar
this is fantastic. great build!
USAF
Blue Crush Build
When is the last time you saw a fully installed upper front control arm pointing straight down?
Really?
spyder6 is offline   Reply With Quote
Old 03-30-2009, 03:25 PM   #59
mazyj
awesome build- very creative, cant wait to see how it ends up
91 wrangler 4.0L, 4 in Suspension lift, 1 inch Shackle Lift, 1 inch Body Lift, 35" BFG Mud Terrains, Warn Rockcrawler Front Bumper, Hand Throttle, HiLift, 12 pack of Natty Boh.
mazyj is offline   Reply With Quote
Old 03-30-2009, 08:29 PM   #60
zluster
Worked on fitting the 2500 fenders and headlights:
Glock Forum
