Please help me find replacement ignition switch! - JeepForum.com
post #1 of 7 Old 10-23-2013, 09:20 PM Thread Starter
ahhforille
1992 MJ Comanche
got it
ahhforille is offline
post #2 of 7 Old 10-25-2013, 05:06 PM
Soldier905
1988 MJ Comanche
That looks like the turn signal switch on the column to me , i had to replace mine on my mj and It turns out GM uses the same parts . (jeep at the time had a mix of every ones parts in their vehicles.)
Soldier905 is offline
post #3 of 7 Old 10-26-2013, 07:18 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
AMC= All Makes Combined.
Here's an ignition switch:
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #4 of 7 Old 10-29-2013, 09:28 AM
ontin000
1989 MJ Comanche
I'm in the process for hunting for my ignition switch, as well. I thought the same thing as the OP, but turns out that part is the headlamp delay module/switch. I'll be going back in and when I find it, I'll take a picture.
I don't understand how the U.S. economy works much less some sort of a self-sustaining one.
ontin000 is offline
post #5 of 7 Old 10-29-2013, 02:15 PM
Soldier905
1988 MJ Comanche
The picture from op is of turn sig switch as a rod comes down from the lever near steering wheel and pushes on that white piece seen on the right in 1st picture (at least thats how my 88 mj was)
post #6 of 7 Old 10-29-2013, 06:06 PM
ontin000
1989 MJ Comanche
I was able to locate my ignition switch today, but it got too dark to take a picture. The switch is on top of the steering column, and actually shares a bolt with the switch from the picture. Notice how the screw was 8mm, and the other was nut was 3/8"? That same stud is the other screw for the ignition switch, which is 8mm. I'll have a picture up tomorrow.
ontin000 is offline
post #7 of 7 Old 10-30-2013, 05:54 PM
ontin000
1989 MJ Comanche
Here is a picture of both switches. I just re-installed them today.
Here is a picture of that studded screw I was talking about. The stud is 8mm, and the nut on it is 3/8"
And here is a picture of the switch in position. I admit, it's hard to get a good shot as there is little space up there, but this is from the centerline of the vehicle facing port (drivers) side.
ontin000 is offline
