Peugeot BA 10/5 to AX-15 - JeepForum.com
post #1 of 5 Old 08-09-2012, 08:20 AM Thread Starter
crowespastureyj
Hi, I'm trying to get ready to start building my 87' Comanche.
And the first thing that I want to do is rid the mj of the BA10/5.
I have a new style ax-15 ready to go in but am wondering if the np231AMC will have the right spline count to go on it.
Thanks,
CJ
crowespastureyj is offline
post #2 of 5 Old 08-11-2012, 09:51 AM
YjStrangler92
Thanks,
CJ
Ive heard the ba 10 trans has a 21 spline like the ax 5 behind the 4 cylinders. Ax15 has 23 splines. I was told you can swap the input shaft on the transfercase (231) from 4 cylinder to 6 cylinder by replacing that shaft. I ve never done it. I hope this helps. Other thing I heard is 231 from manual trans wont work on automatic. So if you find a ax5 231 transfercase, swap input with 23 splines, then your on your way.if you look in salvage yard you may get lucky and find ax15 cherokee. Snag you a t-case from that.good luck bro
YjStrangler92 is offline
post #3 of 5 Old 08-12-2012, 06:50 AM Thread Starter
crowespastureyj
Thanks for your input. I'll post the outcome in a week or two.
CJ
**89' YJ 4.2 GM HEI distributer and webber 2brl. 98' AX-15. NP231. D30 with posi-loc. D35 locked. Rough Country 2.5" Suspention, 1" Body lift mounts. 1" lift shackles in the rear and 33x12.5x15 BFG All-Terrains *87' MJ build Sitting stock with a bit of rust. Has 4.0, Peugeot BA10/5, NP231AMC. Will add as it happens. :)
post #4 of 5 Old 08-12-2012, 07:03 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
The spline count info is correct. The Peugeot has a 21 spline output shaft, while the AX-15 has a 23 spline output shaft.
The input shaft can be swapped, but make sure the 23 spline input shaft must be the same "cut" version as transfer case it is going into. There was a slight change made in the cut of the gears in '94, so you'll need to make sure that both the donor part & the transfer case are on the same side of the cut range.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #5 of 5 Old 08-16-2012, 07:53 PM
Pete M
1988 MJ Comanche
huh? got a link to that?
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
