parking brake light - JeepForum.com
post #1 of 3 Old 04-16-2008, 07:29 AM Thread Starter
USN1982
1989 MJ Comanche
parking brake light
last night i parked my truck as usual and this morning the light for the parking brake stayed on as well as my let turn signal. i know the left turn signal has been doing that for a while and it turns off on its own or at least dims down. the thing is i did not turn on the brakes last night. what can i do to fix it or is their something else.
USN1982 is offline
post #2 of 3 Old 04-16-2008, 09:14 AM
Pete M
1988 MJ Comanche
Check the condition of the individual light sockets. If they get corroded they can short to ground and cause all sorts of weird issues.
Jeep on!
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #3 of 3 Old 04-17-2008, 02:37 PM
wranglercory
Attention !!!!!!!!!!!!!!
CHECK ALL OF YOUR BRAKES !!! You may have a bad wheel cylinder and you may loose your brakes. Mine came on after working the brakes all over and the first time it came on the wheel cylinder went bad the second was a fitting that wasnt tightened enough.
Addicted to Jeeps , had 1994 YJ, &1994 XJ, Have now 1997 XJ, 1996 XJ, &my project 1989 MJ, just bought another 89 MJ with a 4 cyl.
wranglercory is offline
4wd slipping and parking brake light mudman31890 XJ Cherokee Technical Forum 2 10-11-2008 09:43 PM
Brake and parking light problem Bob1991Limited XJ Cherokee Technical Forum 3 11-13-2005 12:25 PM
Parking brake light keeps coming on... NotMatt XJ Cherokee Technical Forum 3 02-22-2004 07:42 PM
Parking Brake Light Stuck On!! ddoffroad XJ Cherokee Technical Forum 3 02-26-2003 04:25 PM
Parking Brake Light? ddoffroad XJ Cherokee Technical Forum 1 02-23-2003 10:58 PM
