Overheating 87 Jeep Comanche - JeepForum.com
post #1 of 10 Old 09-10-2012, 08:55 AM Thread Starter
birdie5
1987 MJ Comanche
Question: I've had this Jeep for about seven months now, ran fine, temp stayed under 200, never overheated. Blew the head gasket two months ago, had it replaced (and the thermostat) and since then, it's over heated twice. This last time the engine sounded like it was boiling and antifreeze spewed out all over the road. Also, since I had the head gasket replaced the temp has been going up and down when I drive, not running at a consistent temp like it did before the gasket was replaced. The mechanic can't figure it out. I really need some help on this one, I have to make a 13 hour trip in two days - anyone have any ideas????
birdie5 is offline
post #2 of 10 Old 09-10-2012, 11:46 AM
DeejayZeejay
1994 ZJ
Radiator replaced and water pump? Check the fins on the condensor and radiator. Make sure they are not bent in or clogged. Replace your temp sensor if original as well.
Jeeps 4 Life!
DeejayZeejay is offline
post #3 of 10 Old 09-10-2012, 11:59 AM Thread Starter
birdie5
1987 MJ Comanche
I believe so, I know the radiator is new, pretty sure the water pump is too. I will tell him to check the other stuff - thanks so much!
birdie5 is offline
post #4 of 10 Old 09-11-2012, 08:34 AM Thread Starter
birdie5
1987 MJ Comanche
Mechanic got back to me - cracked piston
birdie5 is offline
post #5 of 10 Old 09-11-2012, 02:17 PM
dkroll
1988 MJ Comanche
9 times out of ten, if a thermostat without a "bleeder valve" is on it, it will cause you all kinds of crap!!! They always want to sell the one which has no bleeder valve, it can drive you crazy until you get the right one. Be sure to check that out. If it don't....they owe you some money bro!
Without this type, you will get air buildup near the head and will overheat. Your temp gauge will go crazy and (I am assuming this is a 4.0L), you will always have temp issues!!!! Serious!!! Check it out....Thank God it is an easy location and quick job.
Doug
dkroll is offline
post #6 of 10 Old 10-10-2012, 05:47 PM Thread Starter
birdie5
1987 MJ Comanche
Thanks so much, I just read this. I left a message for the mechanic. I just got the Jeep back last week - AFTER HE PUT A NEW ENGINE IN IT - and today it overheats AGAIN!
birdie5 is offline
post #7 of 10 Old 10-11-2012, 06:34 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I only use the factory thermostat 83501426 anymore. Has a jiggle valve/bleed hole.
Do you still have the coolant bottle on the passenger side firewall? When it overheats does the coolant come out around that cap? If so, replace the cap with one from Napa. Part number 703-1396.
cruiser54 is offline
post #8 of 10 Old 10-14-2012, 10:49 PM
ftpiercecracker
1990 MJ Comanche
is that the volvo cap?
ftpiercecracker is offline
post #9 of 10 Old 10-15-2012, 06:50 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
703-1396 is Napa's part number for the Volvo cap.
post #10 of 10 Old 10-16-2012, 08:40 PM
ftpiercecracker
1990 MJ Comanche
Got it.
This is the cap i have and it is fantastic. Had to go through 3 stock caps before i figured it out.
Comanche overheating gonoles MJ Comanche Technical Forum 9 06-04-2012 12:27 AM
New guy, new to Jeep, got an 86' Comanche E4Marty XJ/MJ Cherokee Non-Technical Forum 0 04-24-2012 03:54 PM
Jeep comanche please help!! ComancheMilton MJ Comanche Technical Forum 6 04-10-2012 12:15 AM
jeep comanche comanchee12 MJ Comanche Technical Forum 4 12-26-2011 06:26 AM
Jeep Comanche help taaylorrb MJ Comanche Technical Forum 2 10-30-2009 05:57 PM
