oil in all of the wrong places - JeepForum.com
post #1 of 7 Old 08-27-2011, 01:06 AM Thread Starter
ore4x4
my comanche has an oil leak on the valve cover the rubber fitting is worn out, and there is oil on the air filter.
ore4x4 is offline
post #2 of 7 Old 08-27-2011, 09:22 AM
ftpiercecracker
1990 MJ Comanche
well you probably just need to replace your valve cover gasket, that should solve the leaking. as for the oil in the air filter, what happens is oil fumes that are burned of the motor because of the leak get pulled into the filter and ta da you have an oily filter, but if there is literaly a pool of oil i am not sure what on earth would cause this. It might also be your PCV valve, all very simple things. just ask your local auto parts store. uless you have a washable K&N air filter you should probably get a new one. let me know if this works.
ftpiercecracker is offline
post #3 of 7 Old 08-27-2011, 09:24 AM
ftpiercecracker
1990 MJ Comanche
replace your PCV valve and your air filter.
post #4 of 7 Old 08-29-2011, 06:50 AM
Garvin
1986 MJ Comanche
There is no PCV valve. The PCV is integrated into the valve cover. What you need to do is clean the valve cover up real well in the inside top, find a rubber grommet that fits in the top and replace the air filter. Blow by is a very common issue with these Jeeps and is fairly easy to fix.
1986 Jeep Comanche 126000+ miles
Long Bed, Chevy 350 TPI (5.7L V8), AX15, NP231
Roll Bar, 15/38.5R16.5 Ground Hawgs, Bastard lift (Custom 3-link long arm system, 4.5" Rusty's front springs w/ 1.75" spacers and 6.5" RC shocks, SOA rear), Dana 60HP/Sterling 10.25, 4.10's, Recessed winch, more mods to come...
1992 Jeep Comanche 174000+ miles
Short Bed, 4.0L I6 HO, AX15, NP231
In the process of doing a frame up restoration.
...RIP...
1990 Jeep Cherokee XJ 207774 miles
4.0L I6, AW4, NP231. Tom Woods SYE and Drive Shaft, Rusty's 8.0" Long Arm Suspension Lift, 36/13.5R15 Super Swamper IROK's, Dana 30 Front, Tube Diff Guard, Dana 44 Rear, 4.56 gears, Ox Locker, disc brake conversion
Garvin is offline
post #5 of 7 Old 08-29-2011, 12:15 PM Thread Starter
ore4x4
thanks for the help.
ore4x4 is offline
post #6 of 7 Old 08-29-2011, 04:52 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
This^^. Replace the vacuum harness that includes the valve cover grommets while you're at it. Napa has them priced reasonably.
cruiser54 is offline
post #7 of 7 Old 08-30-2011, 07:01 PM
DonBC
1989 MJ Comanche
When I got my 89 Comanche it was pushing oil over to the air filter when driving and sucking oil into the intake manifold when I was stopped at a light. It would go through about a litre of oil in 500 km. Compression was good and there was little blow-by when the oil filler cap was off on the valve cover. I finally removed the valve cover and saw the source of my problems. Everything under the valve cover was coated with at least 1/4" of sludge. The ventilation passages near the top of the valve cover were plugged so the only opening was near the bottom of the valve cover. The space around the push rods was almost closed off so the oil had trouble getting back to the crankcase and it would build up to the lower ventilation openings in the valve cover and get drawing into either the air filter or the intake manifold. I don't think that this truck ever saw any highway miles, just city stop and go driving. I spent over 6 hours cleaning the valve cover and everything under the valve cover. I flushed the engine twice with kerosene and then engine cleaner just before the next two oil changes. No more smoke and oil consumption is an acceptable 1 litre every 2500 km.
The seller told me it needed an engine overhaul. It turned out to be a cheap fix and it runs beautifully.
DonBC is offline
comanche , oil , oil leak
Stinky grease in all the wrong places mojog XJ Cherokee Technical Forum 5 01-12-2011 03:22 PM
looking for mud in all the wrong places Yj Chico Xj XJ Cherokee Technical Forum 9 08-26-2006 02:16 AM
Lookin for "lockers" in all the wrong places XtremeJeep XJ Cherokee Technical Forum 7 05-27-2006 02:25 PM
Something wrong with Jeep's record of my vehicle - wrong build sheet prior2 XJ Cherokee Technical Forum 16 12-21-2005 04:47 AM
oil in all the wrong places anewman88 XJ Cherokee Technical Forum 1 03-20-2004 11:13 AM
